is it possible to burn an img or iso to 2 writers?
i can extract video_ts folder with iso buster then burn but is it possible to do it straight from img or iso?
here's the only thing i've been able to find that states that it does burn to mulitiple burners at once
Gear Professional
Gear Professional Mastering -
I've burned on up to 3 drives with Alcohol 120%. one SATA (8X), two IDE (16X), at 4X to ensure a good burn (1GB RAM, didn't want to overload buffer). All scans looked fine, and the discs played.
;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep" -
discjuggler
http://www.padus.com/products/discjuggler.php
but recomends the same model of drive and only supports two drives -
DJ can do more than just 2, you just have to have the license for larger amounts (not that much $).
Also, Nero Enterprise edition can do many multiple recorders, either with direct authoring/premastering or with an already premastered disc image (NRG, ISO, etc).
I've got both and know they both work well!
Scott -
Hi,
I recommend using ISO-burner tool. It is extremely easy to use and never failed me. More of it, the util is free and really small.
spammer -
Triangle,
while that may be a decent simple burner app, it DOESN'T do what the OP asked for: simultaneously burn to 2 or more recorders!
Burn Multiple ISO's to one DVD with Menu
By AHWagner in forum Authoring (DVD)Replies: 10Last Post: 4th Jul 2011, 19:54 -
.iso, .img, .cue, etc. to DVD
By Xandal in forum ComputerReplies: 5Last Post: 26th Aug 2008, 12:52 -
IMG/ISO to DVD
By digitalred93 in forum Newbie / General discussionsReplies: 7Last Post: 28th Nov 2007, 23:59 -
Which is best to burn - img, iso or video_ts
By dynamique in forum Authoring (DVD)Replies: 10Last Post: 29th Sep 2007, 15:13 -
Unable to burn with multiple DVD recorders with Nero 7.9.6.0
By Burner127 in forum Authoring (DVD)Replies: 1Last Post: 7th Jun 2007, 00:47
