hey guys, i have an avi file that i want to normalize the volume on (higher it) i did it to previous files with no problem, however on this file when i higher the volume in virtualdubmod surround and i listen to the output file its like most of the file is muted, but a bit of it isnt. very weird, how can i get it working?
http://dspguru.notrace.dk/BeSplitv0.9b6.zip
BeSplit -core( -input in.ac3 -output out.ac3 ) -ota( -G max )
Never tried it, but it should work. -
for some reason it doesnt work like anything i try, i think theres something with the audio stream that makes it like corrupt or something when i edit it, when i play it in media player classic it works fine, if i try to do anything else it cuts the sound, maybe im loosing some of the channels? because i can hear some of the sound afterward its just that like 90% of it is gone (anything extracted has this problem)
yeah its basically just background sounds, like whats going on around but not the main audio
Maybe your dialogue channel has been mapped to something other than center. Try listening to each individual; track, and you can determine which channel needs to be louder.
Depends on your AC3 decoder on your PC. Ac3filter should let you do it.
Another Hit and Miss method is to use "BeLight", re-encoding to AC3 and setting dynamic range compression levels to "heavy".
http://forum.doom9.org/showthread.php?p=571527#post571527
AC3 is difficult to work with - even with commercial tools. -
ohh forgot to add, i have ac3 filter included with k-lite mega codec pack, i raised the main gain on it to raise the volume while its playing, but i still want to figure out why it "removes" the main sound when i try to extract it, or do anything to it.
Audio Normalizing
By dvddemon in forum AudioReplies: 7Last Post: 26th Sep 2011, 21:02 -
Normalizing...
By chobo321321 in forum AudioReplies: 8Last Post: 9th Mar 2011, 23:30 -
Normalizing audio help
By 1031982 in forum AudioReplies: 10Last Post: 23rd Jun 2009, 22:42 -
Normalizing Audio
By evilbubbles in forum AudioReplies: 2Last Post: 7th Dec 2008, 15:04 -
Volume normalizing
By grandsire02 in forum Newbie / General discussionsReplies: 2Last Post: 6th Mar 2008, 11:01
