I have the full paid version of convert x to dvd. I have an .avi file which I want to convert to dvd format. I added the subtitles to it by using ffdshow. They were in the srt format. Now when I converted it to dvd , no subtitles came. Please Help!
Results 1 to 15 of 15
convertxtodvd makes switchable subs if you add the srt in the program, no need for ffdshow. have you tried click on the subtitle button on your remote control or in your dvd software program?
No subs displayed, or no subs available at all to choose ? ConvertXtoDVD doesn't set subs on by default.
Read my blog here.
ConvertXtoDVD wont encode the subs that ffdshow displays on screen. It takes the srt file. This file must be in the same folder as the avi, and have the same name as the avi, but with the srt extension. ConvertXtoDVD will pick up the subs automatically if this is done correctly. You can confirm that the subs have been loaded by expanding the properties of the video in ConvertXtoDVD after loading.
Read my blog here.
in the video preview going on in the right side of the convert x to dvd window while yr convertin .. the subtitles dont appear. ... but on the left in the menu of the dvd it shows one subtitle stream.
You see them in WMP because FFDShow is putting them in the stream. ConvertXtoDVD should ignore this and only create the switchable subs in the DVD.
Read my blog here.
thank you .. guys .. my problem s solved... i have the subtitles on dvd.. but the size is only 2 gb... but the quality is so -so..in convert x to dvd my encoding quality speed was medium quality encoding speed (recommended written dere).. so if i put it to higher quality slow encoding will the quality drastically improve??? nd will the speed drastically decrease???
The speed won't drastically decrease - on my system the difference would be less than 10 minutes. Will the quality drastically increase ? That I can't say, other than to repeat the advice often given here : Garbage In, Garbage Out. If you source is Xvid/Divx avi then you will find that conversion to DVD leaves looking a lot worse than when you watched it on your TV. This is not the fault of ConvertXtoDVD, but the fault of the original encode, and the difference between the PC and you TV. The source has been compressed very heavily to make it fit into 700MB, and has been reduced in size. The lower gamma levels on your PC hide a lot of the compression artifacts in the file. When you encode this file for DVD you have to enlarge the resolution, which makes the artifacts larger, and the higher gamma on the TV makes them more visible. You can use VLC to proves this. Enable the Extended GUI under Settings, then start pushing the gamma levels up. You will quickly see the compression artifacts. ConvertXtoDVD, and any other one-click tools, do not have the adjuments and filters necessary to remove these artifacts. For that you need avisynth or virtualdub. ConvertXtoDVD can read and encode from avisynth scripts.
Read my blog here.
yeah .. thanks for yr advice... but .. i saw the sound quality of the picture.. it wasnt that great.. i have jbl platinum speakers with my comp... i put the full volume in real player of the speaker and the volume control of the comp , den the sound was hearable.. like so-so.. neway to improve this?
ConvertXtoDVD encodes audio to AC3 if it isn't already DVD compliant. For you to hear it on your PC you must have an AC3 decoder installed. You do, because it is there, just very low. Most of the AC3 decoders have their own settings for volume that override windows. You need to find these and make sure they are set correctly.
Read my blog here.
Using AVS2DVD to convert mp4 to DVD - I may have run into a problem
By Akhet in forum Newbie / General discussionsReplies: 3Last Post: 14th Apr 2011, 20:43 -
Problem convert DVD file to xvid with combine audio channels
By Aquatoid in forum Video ConversionReplies: 5Last Post: 26th Feb 2010, 16:45 -
Convert AVI and burn to DVD: problem w/ NERO
By jimbo213 in forum Video ConversionReplies: 3Last Post: 3rd Aug 2009, 04:10 -
Convert Problem
By ewbanks in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 7th Aug 2007, 18:38 -
convert x dvd problem
By tofu in forum Video ConversionReplies: 4Last Post: 16th May 2007, 11:13
