Hi,
Thanks for your help. My question is that I have a wire connected from my computer to the TV, and the TV shows my desktop but when I play a video, it plays on the monitor but doesnt show on the TV. Is there anything I can do to fix this? I have used WMP, RealPlayer, VLC Player, and Winamp but nothing works. THanks a lot!
Try this: In VLC: 'Settings>Preferences>Video>Advanced Options' (Check this- It's near the bottom of the page) Then uncheck the 'Overlay video output' that should now be showing.
If that doesn't work, in your computer: 'Control Panel>Display>Settings>Advanced>Troubleshoot'. Lower 'Hardware acceleration' to about 1/3 of the way across. The overlay settings are usually the problem. You can change them in some players like VLC or change them globally in the video card settings.
And welcome to our forums.
Thanks a lot! I will be using these forums a lot now since I got a lot of movies to put on DVDs and such. And thanks again
Computer for editing HD video
By jason_31 in forum Newbie / General discussionsReplies: 5Last Post: 13th Sep 2011, 23:38 -
Sending video from my computer to TV?
By NeWcS in forum ComputerReplies: 26Last Post: 16th Jul 2011, 11:16 -
Computer for Transcoding Video
By sarnold in forum MacReplies: 6Last Post: 26th May 2011, 18:40 -
What computer should I get for capturing video?
By duderdude2 in forum ComputerReplies: 0Last Post: 10th Dec 2009, 01:17 -
Computer for video editing
By ProducerHarley in forum EditingReplies: 2Last Post: 19th Oct 2008, 23:23
