    I just finished converting a file that was an XviD AVI (created by ffmpegX with subtitles burned in) from which I then altered the A/V sync (using QT Sync) and saved as a QT reference movie. It was this reference movie that I dropped into ffmpegX and converted to the new LC H264. (*whew*)
    No apparent problems. However, when I looked into the conversion info, I saw this:
    Adding iPod atoms..
    2006-10-20 17:51:55.610 movtool[1608] CFLog (21): dyld returns 2 when trying to load /Library/QuickTime/AviImporter-r7 (Intel).component/Contents/MacOS/AviImporter
    2006-10-20 17:51:55.745 movtool[1608] CFLog (21): dyld returns 2 when trying to load /Library/QuickTime/XviD_Codec-r58 (Intel).component/Contents/MacOS/XviD_Codec
    2006-10-20 17:51:55.751 movtool[1608] CFLog (21): dyld returns 2 when trying to load /Library/QuickTime/XviD_Codec-r58 (Intel).component/Contents/MacOS/XviD_Codec
    2006-10-20 17:51:55.759 movtool[1608] CFLog (21): dyld returns 2 when trying to load /Library/QuickTime/XviD_Codec-r58 (Intel).component/Contents/MacOS/XviD_Codec
    2006-10-20 17:51:55.764 movtool[1608] CFLog (21): dyld returns 2 when trying to load /Library/QuickTime/XviD_Codec-r58 (Intel).component/Contents/MacOS/XviD_Codec
    2006-10-20 17:51:55.771 movtool[1608] CFLog (21): dyld returns 2 when trying to load /Library/QuickTime/XviD_Codec-r58 (Intel).component/Contents/MacOS/XviD_Codec
    2006-10-20 17:51:55.779 movtool[1608] CFLog (21): dyld returns 2 when trying to load /Library/QuickTime/XviD_Codec-r58 (Intel).component/Contents/MacOS/XviD_Codec
    2006-10-20 17:51:55.784 movtool[1608] CFLog (21): dyld returns 2 when trying to load /Library/QuickTime/XviD_Codec-r58 (Intel).component/Contents/MacOS/XviD_Codec
    2006-10-20 17:51:55.929 movtool[1608] CFLog (21): dyld returns 2 when trying to load /Library/QuickTime/AviImporter-r7 (Intel).component/Contents/MacOS/AviImporter
    2006-10-20 17:51:55.936 movtool[1608] CFLog (21): dyld returns 2 when trying to load /Library/QuickTime/AviImporter-r7 (Intel).component/Contents/MacOS/AviImporter
    Obviously, there were other notes but these were the only "errors"(?). I do see the AviImporter codec in the QT folder. Any ideas what was going on? The resulting file dropped into my iPod and plays well. I'm not looking for trouble but I am curious.
    Thanks.
  2. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    Googling reveals it has something to do with Universal Binaries and compiling for either or both chipsets. I couldn't figure out if it's a comment or an error message, tho'.
    The same messages are coming up in all of my H264(LC) conversions. All resulting files drop into my iPod without any issue so I imagine "dyld returns 2" may mean "Intel" (as that is the iMac I have).
    Thanks for your reply.
