I took a 528x400AVI and encoded it to a 720x480 MPG. I would have thought the mpg would be smaller due to compression. Is the reason the MPG is larger that I was going up to 720x480?
I've had similar results.
I tried to convert a 50mb (taken from my canon digital camera - 30 seconds video) to mpeg and the converted file was 70mb. I don't understand.
I am trying to shrink that avi file to as small as possible to email as attachement.
Any clues or help?
Pat -
AVI is a container and may have video and audio compressed with any number of codecs. In all likelihood your AVI file had MPEG4 (Divx/Xvid) video that is much more compressed than MPEG. Not only that but you enlarged the frame which requires even more bitrate.
The file size is determined by two things: the running time times the bitrate. If you want a smaller file use a lower bitrate. Of course, the lower the bitrate, the less the quality. -
[edit]
Sorry jagabo. you posted while I was typing.
I guess I type too slow.
later -
Originally Posted by jagabo
Good luck everyone, and have a good weekend.
PowerDirector makes final DVD files, size larger than mpg file's size, why?
By Xor2 in forum Authoring (DVD)Replies: 4Last Post: 22nd Dec 2011, 17:29 -
Getting larger files than expected using Xvid to compress AVI
By pronco in forum Capturing and VCRReplies: 50Last Post: 7th Sep 2011, 10:42 -
HDConvertToX keep getting "AVI files larger than 2000 MB" error
By jsbenson in forum Video ConversionReplies: 3Last Post: 4th Nov 2009, 21:20 -
2 Small-ish AVI -> 1 Larger AVI = HUGE File. Why?
By cxp36 in forum Newbie / General discussionsReplies: 2Last Post: 6th Mar 2008, 17:31 -
larger file size from .avi to h264
By sai351 in forum Video ConversionReplies: 3Last Post: 4th Jun 2007, 13:20
