I cant hear anything when i try to play a dvd, but when I play music or videos from the hard drive or internet it works. what can I do?
I've tried REAL PLAYER, WINDOWS MEDIA PLAYER 11, CYBERLINK POWER DVD, and all have the same result, no sound.
That could work, but then it still doesn't fix the problem of my laptop not playing dvds correctly.
Is it possible the CODECs for audio (Dolby, etc) are not installed or have been corrupted on your machine?
Try reinstalling PowerDVD or another decent DVD player app and see if that helps correct
the issue.
Sabrowww.sabronet.com - It's all you need...to know
CD-ROM vs. DVD-ROM
By Judson in forum MacReplies: 10Last Post: 6th Apr 2012, 08:33 -
Another DVD Rom issue
By dafoe in forum DVD & Blu-ray WritersReplies: 5Last Post: 16th Jul 2010, 11:49 -
CD \ DVD ROM not seen in Windows
By lacywest in forum ComputerReplies: 1Last Post: 16th Oct 2009, 09:19 -
dvd rom discs
By johnbud in forum MediaReplies: 3Last Post: 26th Jul 2007, 06:03 -
hd-dvd rom drive
By computerchuck in forum Software PlayingReplies: 6Last Post: 8th May 2007, 07:55
