when i try to add the iso file into dvdshrink it says 'invalid UDF filesystem'
i cannot load the iso file at all
dvddcrypter does burn it, but when i play it in my dvd player nothing happens. says its loaded, but after that nothing happens. just stays at my dvd opening screen
anyone know what the problem is?
Where did you get the ISO from? It sounds like a corrupted file. You could extract the file with a program like ISOBuster. Or mount it with a program like Daemon Tools, or view it with VLC Media Player. VLC plays ISO's.
If you mount it with Daemon, you should also be able to see the DVD format or use that in DVD Shrink, if it isn't corrupted. -
well i cant really say where i got the iso file from, i dont wanna break the rules lol
it plays with vlc, and the the burnt disc plays on my computer dvd player, but not my tv dvd player.... so i guess im stuck, i dont really care to watch it on my comp either so i guess its a loss
ill try isobuster tho first
Strange burning issue with DVDShrink/Nero combo
By RoyGBiv-inRI in forum DVD RippingReplies: 7Last Post: 7th May 2010, 12:00 -
Problem with DVDShrink
By abba1961 in forum DVD RippingReplies: 3Last Post: 22nd Mar 2010, 02:52 -
DvdShrink process stuck after burning to dvd .
By fibola in forum Authoring (DVD)Replies: 8Last Post: 19th Sep 2008, 12:17 -
Problems Burning Discs with DVDshrink/Nero
By iownju in forum DVD RippingReplies: 5Last Post: 20th Jul 2008, 16:56 -
Can DVDShrink be set to use ImgBurn for burning?
By RoyGBiv-inRI in forum DVD RippingReplies: 7Last Post: 21st Jul 2007, 14:17
