I downloaded subtitles which are very messed up, different parts of the subtitles have different delays. If I adjust the very first subtitle, later on they're out of sync again, and it happens several times throughout the whole subtitles. I downloaded Subtitle Workshop and learned how to adjust different parts using Add subtitle/video synchonization point button. I found at which point of the movie the subtitles go out of sync again and adjusted them, and repeated it as many times as necessary.
However, after I adjust the subtitles to the movie and save the file, when I open it again, the time when each subtitle starts has shifted. If I for example set the start of the first subtitle to frame 315, when I reopen the file, the frame will be moved to 236. It also seems that the same scene in the movie has different timing as I play it again. For example, one particular scene starts at 00:06:12,527, and when I open the movie again, it will start at 00:07:23,263. I tried working both in time and frames mode. I think the frames markings stay the same for the movie, but when I adjust subtitles working with the frame numbers, save them and open again, yet again they would be changed.
I tried searching through the old posts to find if anyone else has similar problems, the only post I found that approximately describes my problem is this one: https://www.videohelp.com/forum/archive/t273151.html
Do you know how to fix this? Or should I maybe try and download VisualSubSync, if it's better to fix my problem?
Thank you very much for your help!
Results 1 to 1 of 1
Extracted subtitle timing problem.
By Orange-kun in forum SubtitleReplies: 0Last Post: 2nd Mar 2011, 12:20 -
mkv2vob subtitle timing problem
By HeroSmero in forum Video ConversionReplies: 1Last Post: 5th Jan 2010, 18:31 -
Importing timing into Subtitle Workshop
By yonyz in forum SubtitleReplies: 2Last Post: 9th Feb 2009, 11:04 -
Enable editing of "Hide" timing of subtitles in Subtitle Workshop
By ecc in forum SubtitleReplies: 2Last Post: 31st Jan 2008, 06:35 -
Problems with timing using Subtitle Workshop
By Antus77 in forum SubtitleReplies: 1Last Post: 24th Jun 2007, 20:27
