I'm having trouble encoding a file using ASS subtitles. No matter what options you choose for them, it will always use the default settings when encoding.
I'm trying to use a different font (Osaka), UTF-8 encoding, font size 2 and position 98, but it always shows up as the default (Arial, one of those ISO things, font size 1 and position 80).
I'm using a matroska file as the source and trying to output it to a MPEG4 using mencoder.
matroska info:
video: h264, yuv420p, 1280x720
audio: mp3, 48000 Hz, stereo
output (for some reason it still says the preset is AVI DivX even though I've changed it to MPEG4) info:
video: mencoder mpeg4, 640x352, 1265kbps, 25 fps, no crop
audio: mp3, 48000 Hz, 128 kbps
If you need any more information about any of the options I'm using, please ask. Thank you for any help you can provide.
There is a bug in the latest mencoder binaries concerning subtitles. You have to use the binaries that came with version 0.0.9s instead. These will accept different fonts, location and sizes.
There may be a problem that this old version won't decode the h264 mkv correctly, so maybe you are forced to do a double conversion, mkv->avi w/o subs with the latest mencoder and then avi->avi with subs using the old mencoder.
That's what I did with some files I encountered.
External subs don't play correctly with Anime .mkv with embedded subs (.ass
By Reveur in forum Software PlayingReplies: 1Last Post: 8th Nov 2011, 03:20 -
Adding .ASS to MKV file with mkvmerge not working!
By HouseMD in forum SubtitleReplies: 2Last Post: 2nd Sep 2010, 08:24 -
Burning .mkv file with .ass subtitles to DVD WITH the subtitles
By isfjinfj in forum Authoring (DVD)Replies: 2Last Post: 23rd Jun 2009, 17:28 -
4 port capture card - avermedia lx5004 - not working correctly
By 4dplane in forum Capturing and VCRReplies: 3Last Post: 21st Nov 2007, 21:39 -
Anyone else have a RCA DRC247N that has audio not working correctly?
By jeff d in forum DVD & Blu-ray PlayersReplies: 4Last Post: 22nd Aug 2007, 01:06
