  1. I have a Ricoh DVD/CD-RW burner and made a VCD using Roxio Easy CD Video CD Creator 5. After that, I tried playing but the problem was there was nothing on the disk. The properties said there was zero files and zero space. I am using Windows XP by the way, so I don't if that has anything to do with it. But I would appreciate if someone can help me out with this, thanks.
    May 2001
    malaysia
    i'm also facing this problem.
    i've got creative cd writer and WinXP PRO. anybody help..
    Feb 2001
    Palmdale, CA
    cd creator 5.0 does not work with windows xp, you have to upgrade to 5.1 platinum, this is free if you are a regitered owner of 5.o platinum. Otherwise you will have to buy it, or you can use nero 5.5 or vcdeasy.
  4. I am using EZCD creator 5 Platinum in Win XP Pro & it works just fine providing you get the updater from roxio's web site. I am also using Nero 5.564 it also works well for both decoding as well as burning.
    anyone wants either one let me know perhaps we can trade something.
    halljm@mts.net
    Feb 2001
    Palmdale, CA
    I think that is what I just said....lol
    and when you upgrade it goes from 5.0 to 5.1...*S*
