So I had heard that some have had luck using VLC to view DVD's without the need to change the region codes. I have tried this on multiple computers running OSX.4.7 and 4.8, no luck, any info, thanks Wayne.
If the Thunder don't get you,
the Lighting will. -
You may use the File>Open Disc command in the menu or drop a VIDEO_TS folder onto the VLC icon. Menus and title transitions have minimal support, so some discs may not work 100%.
An RPC1 drive could be a requirement, as RPC2 drives have region control in hardware.
Region codes
By pwha in forum Newbie / General discussionsReplies: 5Last Post: 2nd Nov 2010, 08:42 -
Re: Region Free Codes
By beatus11 in forum DVD & Blu-ray PlayersReplies: 8Last Post: 26th Nov 2009, 08:48 -
Multi Region / Region Free codes
By Flying_Dragon in forum DVD & Blu-ray PlayersReplies: 2Last Post: 19th Jan 2009, 09:10 -
HELP region codes
By MNYCITY in forum DVD & Blu-ray RecordersReplies: 9Last Post: 25th Sep 2008, 22:28 -
looking for region free codes
By starlate in forum DVD & Blu-ray PlayersReplies: 4Last Post: 18th Jun 2007, 19:05
