Results 1 to 22 of 22
    Apr 2005
    Canada
    I used the apps in the subject, and the resultant DVD has no audio. I selected the audio to KEEP from the interface screen (English). The original VTS's have audio, but the encoded DVD does not. Here is the log:
    [20:39:46] One Click encoding activated...
    [20:39:47] Phase I, PREPARATION started.
    - DVD-RB v1.10.7
    - CCE 2.70.2.0 encoder selected.
    - VTS_01: 3,673,628 sectors.
    -- Scanning and writing .D2V & .AVS files
    -- Processed 253,146 frames.
    -- Building .AVS and .ECL files
    - Reduction Level for DVD-5: 55.8%
    - Overall Bitrate : 2,709Kbs
    - Space for Video : 3,348,636KB
    - HIGH/LOW/TYPICAL Bitrates: 4,377/400/2,709 Kbs
    [20:46:45] Phase I, PREPARATION completed in 7 minutes.
    [20:46:45] Phase II ENCODING started
    - Creating M2V for VTS_01 segment 0
    - Creating M2V for VTS_01 segment 1
    - Creating M2V for VTS_01 segment 2
    - Creating M2V for VTS_01 segment 3
    - Creating M2V for VTS_01 segment 4
    - Creating M2V for VTS_01 segment 5
    - Creating M2V for VTS_01 segment 6
    - Creating M2V for VTS_01 segment 7
    - Creating M2V for VTS_01 segment 8
    - Creating M2V for VTS_01 segment 9
    - Creating M2V for VTS_01 segment 10
    - Creating M2V for VTS_01 segment 11
    - Creating M2V for VTS_01 segment 12
    - Creating M2V for VTS_01 segment 13
    - Creating M2V for VTS_01 segment 14
    - Creating M2V for VTS_01 segment 15
    - Creating M2V for VTS_01 segment 16
    - Creating M2V for VTS_01 segment 17
    - Creating M2V for VTS_01 segment 18
    - Creating M2V for VTS_01 segment 19
    - Creating M2V for VTS_01 segment 20
    - Creating M2V for VTS_01 segment 21
    - Creating M2V for VTS_01 segment 22
    - Creating M2V for VTS_01 segment 23
    - Creating M2V for VTS_01 segment 24
    - Creating M2V for VTS_01 segment 25
    - Creating M2V for VTS_01 segment 26
    - Creating M2V for VTS_01 segment 27
    - Creating M2V for VTS_01 segment 28
    - Creating M2V for VTS_01 segment 29
    - Creating M2V for VTS_01 segment 30
    - Creating M2V for VTS_01 segment 31
    - Creating M2V for VTS_01 segment 32
    - Creating M2V for VTS_01 segment 33
    - Creating M2V for VTS_01 segment 34
    - Creating M2V for VTS_01 segment 35
    [05:50:36] Phase II ENCODING completed in 544 minutes.
    [05:50:37] Phase III, REBUILD started.
    - Copying IFO, BUP, and unaltered files...
    - Processing VTS_01
    - Reading/processing TMAP table...
    - Rebuilding seg 0 VOBID 1 CELLID 1
    - Rebuilding seg 1 VOBID 1 CELLID 2
    - Rebuilding seg 2 VOBID 1 CELLID 3
    - Rebuilding seg 3 VOBID 1 CELLID 4
    - Rebuilding seg 4 VOBID 1 CELLID 5
    - Rebuilding seg 5 VOBID 1 CELLID 6
    - Rebuilding seg 6 VOBID 1 CELLID 7
    - Updating NAVPACKS for VOBID_01
    - Rebuilding seg 7 VOBID 2 CELLID 1
    - Rebuilding seg 8 VOBID 2 CELLID 2
    - Rebuilding seg 9 VOBID 2 CELLID 3
    - Rebuilding seg 10 VOBID 2 CELLID 4
    - Rebuilding seg 11 VOBID 2 CELLID 5
    - Rebuilding seg 12 VOBID 2 CELLID 6
    - Rebuilding seg 13 VOBID 2 CELLID 7
    - Updating NAVPACKS for VOBID_02
    - Rebuilding seg 14 VOBID 3 CELLID 1
    - Rebuilding seg 15 VOBID 3 CELLID 2
    - Rebuilding seg 16 VOBID 3 CELLID 3
    - Rebuilding seg 17 VOBID 3 CELLID 4
    - Rebuilding seg 18 VOBID 3 CELLID 5
    - Rebuilding seg 19 VOBID 3 CELLID 6
    - Rebuilding seg 20 VOBID 3 CELLID 7
    - Updating NAVPACKS for VOBID_03
    - Rebuilding seg 21 VOBID 4 CELLID 1
    - Rebuilding seg 22 VOBID 4 CELLID 2
    - Rebuilding seg 23 VOBID 4 CELLID 3
    - Rebuilding seg 24 VOBID 4 CELLID 4
    - Rebuilding seg 25 VOBID 4 CELLID 5
    - Rebuilding seg 26 VOBID 4 CELLID 6
    - Rebuilding seg 27 VOBID 4 CELLID 7
    - Updating NAVPACKS for VOBID_04
    - Rebuilding seg 28 VOBID 5 CELLID 1
    - Updating NAVPACKS for VOBID_05
    - Rebuilding seg 29 VOBID 6 CELLID 1
    - Updating NAVPACKS for VOBID_06
    - Rebuilding seg 30 VOBID 7 CELLID 1
    - Updating NAVPACKS for VOBID_07
    - Rebuilding seg 31 VOBID 8 CELLID 1
    - Updating NAVPACKS for VOBID_08
    - Rebuilding seg 32 VOBID 9 CELLID 1
    - Updating NAVPACKS for VOBID_09
    - Rebuilding seg 33 VOBID 10 CELLID 1
    - Updating NAVPACKS for VOBID_10
    - Rebuilding seg 34 VOBID 11 CELLID 1
    - Updating NAVPACKS for VOBID_11
    - Rebuilding seg 35 VOBID 12 CELLID 1
    - Updating NAVPACKS for VOBID_12
    - Updated VTS_C_ADT.
    - Updated VTS_VOBU_ADMAP.
    - Updated IFO: VTS_01_0.IFO
    - Updating TMAP table...
    - Correcting VTS Sectors...
    [06:10:22] Phase III, REBUILD completed in 20 minutes.
    Done.
    [06:10:22] PREPARE/ENCODE/REBUILD completed in 571 min.
    Apr 2004
    Miskatonic U
    If you open the compiled DVD on your HDD using something like PowerDVD, can you change the audio track ? It could be that the track has been incorrectly mapped.
    You could also confirm the existence (or not) of an audio track with G-Spot 2.60
    Read my blog here.
    Apr 2005
    Canada
    I already deleted the folder. In PwerDVD I checked the audio and it had a checkmark beside English. Will let update you on the weekend when I encode it again. Will check with Gspot (which I have). thanks.
  4. Member kush's Avatar
    Jul 2004
    Near "Pacific Park", USA
    If it is incorrectly mapping the audio streams for some reaosn, there is a remapping option in (surprise! ) the options tab of DVD-RB. [edit] Settings -> options since you're not using either the default or Teck skins. [/edit]
    ps Any particular reason why you're using 1.10.7 still? JDobbs is up to 1.10.9 now... There's nothing that I recall in the 2 latest releases that reference audio bug fixes in particular, but maybe if you got up to date it would solve the mapping issue. On the flip side, if this is a reproducible error for you, perhaps you've found a problem that should be reported to JDobbs in the doom9/RB forum(s).
    Apr 2005
    Canada
    here is a screenie of GSpot
  6. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    According to this, the audio is there, is it 2.1 AC3 encoded at 192 kbps, and it is mapped to English.
    Read my blog here.
    Apr 2005
    Canada
    Nothing in powerDVD. When I open the original DVD9 (files on my computer) it has sound. The encoded one does not. very frustrating.
  8. You're in Canada, yet you have an R2 PAL DVD of a US TV series? If so, then I'd guess that one of the European languages is the default stream, and as mentioned before, you'll have to remap it. Which language is the default when you play the retail DVD? Let's say it's German, the second stream. I'd open the DVD in PGCEdit, double-click the episodes in turn, open the first audio stream, and move the slider to "1" if German is the default, "2" if Spanish, etc. OK your way out of there, and do it for the other episodes. Also do it for the "Play All" stream if there is one. The "Play All", if it exists, will have a length equal to the sum total of the lengths of the episodes. Then save your work and test it out in PowerDVD. If something messes up, replace the IFOs which PGCEdit saves automatically, and start over.
    Apr 2005
    Canada
    WOW...I think that is a little over my head. i wonder why the original works fine but the recoded one does not...
    I have a DVD player that plays both PAL and NTSC so it does not matter.
  10. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Even if one of the other languages had been mapped (and I find it unlikely, although not impossible that it has), it would at least play. That no audio is playing, even though one is clearly in the VOB structures, is very odd.
    Read my blog here.
  11. WOW...I think that is a little over my head. i wonder why the original works fine but the recoded one does not...
    If you'd try out the proposed remedy and answer the question, instead of making silly comments (to which I already gave one possible explanation), we might be able to get to the bottom of this. You're the one with the problem, not I. I could easily be wrong, but we'll never know unless you do some work. If you find the "fix" too difficult to follow, here it is with pictures:
    http://forum.digital-digest.com/showpost.php?p=296707&postcount=1
    And like I said, there's an easy "undo" if you mess up.
    guns1inger-
    It may be unusual that an audio stream other then the first is the default, but I see it with some frequency. I picked the German stream as the possible default (not confirmed by caper) because of their habit of doing just that. I see anime sometimes where the Japanese track is the first one, but the English track (the 2nd one) is the default. And if the second stream is the default, but only the first stream still has audio, then no sound, and you have to remap. I've done it a bunch of times. He's using DVD-RB, so he can do it within that app using the "Audio Track Remapping" feature of the Pro version, although it's easier to do it in PGCEdit after having already created the DVD. Another thing caper hasn't mentioned is whether or not he can choose English with the remote or in the setup menu or in PowerDVD. Since DVD-RB doesn't actually wipe out the missing audio streams (the ones he removed are still there, but just empty), he should be able to select English in PowerDVD (if playing the DVD, and not the Vobs), or by using the remote on the standalone, even if he gets no audio at default settings.
    Apr 2005
    Canada
    I select English in PowerDVD and still nothing.
    Apr 2005
    Canada
    OK, I opened the VTS set in PGCEdit. then clicked one of the episodes, and then clicked EDIT PGC and then clicked on the first Audio (Audio VOB's Streams...0) and it came up Audio 0:en, unspecified (AC3). Leads me to believe its already set as default? Thanks for advice so far, anything else that can be done? Also, the default language is English when I play original in PowerDVD.
  14. Hehe, you didn't yell at me for being rude. Sorry. Thanks for trying PGCEdit. Not so hard, eh?
    That's the thing; if it isn't set as the default, then that's where you'll have problems. You'll have to move the slider to whatever is the default audio. That's why I asked what language plays when you play the retail DVD. All you've proven is that the English Audio is the first audio stream, which you knew already. As I mentioned last time, the first audio stream is usually, but not always, the default stream. I can't be sure at this stage, but I'm betting a different audio is the default, probably the German track.
    So, put the retail DVD in the drive and play an episode. Or in your standalone. Take note of which language is default (if something besides English), and move the slider to that language. If you no longer have the DVD, then move that slider first to 1, Save and Test, to 2, Save and Test, etc., until you hit the right one.
    You can't break anything. Immediately upon opening the DVD, PGCEdit saves the IFOs. If something messes up, just move those IFOs back into the DVD.
    Apr 2005
    Canada
    Apr 2005
    Canada
    So this is what you want me to do: Click on the English audio (button "0") and put slider to "1" which is where the dutch audio is/was.
    Background:
    I press Audio button 0, and it says "Audio 0:en, unspecified (AC3)"
    I press Audio button 1, and it says "Audio 0:de, unspecified (AC3)"
    Here is a screen of what I did. (see screen shot)
    Apr 2005
    Canada
    So I clicked on an episode ( on left pane ) and opened it for editing as seen above. I clicked on the Audio 0 button (english) and put slider from 0 to 1, then I hit OK. I did this for all 4 episodes. (Since its not just one main movie). I then hit OK each time to bring me back to main window and then File > Save DVD. I checked in powerdvd, still nothing...I think you mentioned incrementing slider and trying the rest...will do that now.
  18. Member
    Apr 2005
    Canada
    OK. That did not work. I only did it for the English audio track (Audio 0), and changed slider up each time and resaved DVD, and opened in powerdvd each time...still no sound. (pulling hair out now).
  19. Also, the default language is English when I play original in PowerDVD.
    Yes, you said it, and I completely missed it. And I'm at a loss now. I was kind of hoping that one of the others was default, which would explain your problems, and the fix would work. I find it hard to believe that DVD-RB has messed up somehow, as it's a very fine piece of software. It's designed to keep everything the way it was originally.
    Do you get any audio at all when just playing the vobs, like double-clicking on them, or playing one in Media Player Classic (not the DVD, but a Vob)? Have you tested the retail DVD in a standalone DVD player hooked up to a TV set? Have you burned the backup to disc (a DVD-RW perhaps) for testing? Is this the only time this has happened to you, that is, have other DVD-RB projects worked in the past? I'm wondering now if you even have working AC3 on your computer. Do you have the AC3 filter installed? Yes, it should work anyway, if you have PowerDVD, but something very unusual is happening here. I guess then, that you should replace the IFOs that PGCEdit saved for you, if you haven't already. If you still have the original decrypted Vobs on the hard drive, maybe do the project again.
    About all I can suggest at this point is posting about it in the DVD-RB Forum at Doom9. One thing they're going to want to know (as was asked here earlier) is why you don't have the most up-to-date DVD-RB Pro (Version 1.11.0). If you have a cracked version, then I wouldn't post there.
    Apr 2005
    Canada
    My guess is that CCE cracked by "paradox" is the problem. Its like they disassembled the install file and made their own, already cracked, noted by the crazy "splash" screen when you install CCE. I will try recoding it with another version of CCE tonight. I will post my results.
    No I did not burn to a dvd-rw for testing as all dvds have played fine in powerdvd before burning. Thanks a million for all your help so far. Setting up DVD-RB right now. Cheers.
    You are in breach of the forum rules and are being issued with a formal warning.
    / Moderator redwudz
  21. I wouldn't think it's the version of CCE, as it has nothing to do with the audio, which is added in when authoring. Something else is at work, although at this point I don't know what it is. I know there was a cracked version of DVD-RB Pro that left a message on the screen at intervals. I don't know if there's one that prevents the audio from playing, although I doubt it.
    I don't think we're supposed to discuss warez on this site.
  22. Mod Neophyte redwudz's Avatar
    USA
    caper, discussing the use of a 'cracked' copyrighted program is considered Warez on this site and is in violation of our rules. Please read our rules before posting.
    Moderator redwudz
