I was authoring some mpg's that were svcd spec 480x480. I didnt get good results with tmpgenc so I tried Nero Vision. I had great results as opposed to my results from my tmpgenc mpeg1. But I cannot change the setting of format. Its just greyed out at mpeg2.
Does anyone know what I can do to trigger that dropdown menu to work.
On a sidenote: i was using mpeg svcd 480x480, encoded as 704 x 480 mpeg2. I was amazed at the quality when there was little movement in the video. But when there was alot of movement, the moving objects/persons seem to have horizontal lines on them.
1. I thought by stretching the resolution the overall quality would be worse. How come it was so good?
2. What setting or spec can change the horizonal lines thing. Even when I do frame by frame at a fast action scene. The objects have tiny lines striping through them. The whole thing sorts of blurs the whole picture when the action is going on.
Results 1 to 1 of 1
Vegas to Nero Vision?
By zapster in forum Authoring (DVD)Replies: 3Last Post: 21st May 2008, 21:29 -
HELP Burn using Nero Express doent work /but NERO VISION work fine
By STAR36 in forum Authoring (DVD)Replies: 4Last Post: 28th Apr 2008, 17:11 -
Nero Vision 5 Help
By luckyboym in forum Authoring (DVD)Replies: 1Last Post: 25th Feb 2008, 01:47 -
need help with Nero 8 and Nero Vision 5 (figuring Extended Play Plus)
By Edward Benavides in forum Newbie / General discussionsReplies: 2Last Post: 31st Oct 2007, 12:10 -
Nero Vision 5
By marioval in forum Authoring (DVD)Replies: 0Last Post: 11th Oct 2007, 14:45
