  1. Member solarblast's Avatar
    Nov 2004
    N. California. USA
    I'd like to make a still with text to the left and a small jpg file to the right of it, or somewhere outside the text area. What plug-ins will allow me to do this? I'm aware of laying text over an image by using an image on track 2 and placing the Sony Text plug-in above it on another track. Maybe there's something with fixed text and a movable clip. I don't want to Vegas to stretch out the image as it does when it normally gets inserted into a video track.
    Apr 2004
    Miskatonic U
    Check the way you have Vegas configured, because it doesn't distort iomages when I load them.
    That said, you can use Event Pan/Crop or Track Motion to resize and re-position an image anywhere on the screen in Vegas. Put this track above the base track, as you would text, and it is overlayed. No plugins necessary.
    I do this type of thing often for making motion menus for DVDs.
    Read my blog here.
  3. Member solarblast's Avatar
    Nov 2004
    N. California. USA
    Actually it would be good to go one step further--two pictures. I would guess there is somewhat to achieve that by yet using another track. So one would have a video base, and two other video tracks?
    Apr 2004
    Miskatonic U
    Yes. Just add as many tracks as you need. Vegas supports unlimited tracks.
    Read my blog here.
  5. Member solarblast's Avatar
    Nov 2004
    N. California. USA
    I've used pan/crop a little, basically to play with the box controls and rotation. I thought I'd give the selectors a whirl, source, position and so on. It seems as though when I change an x or y coordinate and then exit that when I come back the value is the original. What's going on? Is there a button that says something like "Set Values"?
    If there's a Help area in Vegas that explains the entire preset, I'd like to know where it is.
  6. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Track motion is something you should look at as well
    Read my blog here.
