    Oct 2006
    Hello,
    I'm sure you're all aware that ati MMC 9.15 blows. I decided to try it out anyway because i was sick of using 8.5 (came with ym card), because in order to play counter-strike source, i needed a newer driver, which wont allow me to use the record feature with MMC 8.5. Since I've heard MMC 9.08 is one of the best and most stable versions, I was wondering if any of you guys knew if Cat 6.9 would allow MMC 9.08 to work properly and to its fullest ability.
    Thanks for your time
    Oct 2006
    Sorry, it's me again. I was also wondering if there is any other tv software that works with my 9800 AIW, that isnt a compete joke like all ATI software.
  3. I am using the MMC 9.08 with the 6.9 without problems on my AIW9000
