so i want to back up some music a few gigs to dvdr and as im trying in nero as data, i recieve a error that causes a blue screen then a shut down. im thinking it's usually with a corrupted file i'm trying to burn that makes it happen
are there any programs that i could use that would go error free and burn my data disc all the way throughout?? even if say a song or two dont read/burn correctly? (i cant seem to find the file which is causing the error) or maybe a program that allows me to see what exactly is being burned as it's going so i know if i get an error on a certain filename it is that specific one corrupt![]()
Results 1 to 10 of 10
I have never used it myself but in another recent thread a respected forum member suggested using a program called CDBurnerXP Pro for burning Data DVD discs.
Here is a direct link ---> CLICK HERE
I plan on trying it the next time I need to burn a Data DVD which is something I do but not very often. In the past I have used NERO for this although I have never been a fan of NERO as I use a program called ImgBurn for my DVD Video burning needs.
Audio DVD Creator
It let you backup CD as DVD sound tracks, so you can check it with your ear. -
right will check those out,but ive got an update as to what could be the problem
tried one more time again, as data dvd in nero - and this time my pc didnt shut just "error(ed)" around 19% and i was able to get a Log. ive attached it.
any idea as to what it could be/what i can do?
log.txt -
Are you certain you are burning with Nero Burning ROM purely as data? I've never heard of a BSOD occurring in this manner.
If that's the case, write down your Nero serial number and try using the CleanTool from Nero's site. Then install Nero 7.0.8.2 (if you have a license for Nero 7) or Nero 6.6.0.18 (if you have a license for Nero 6.) These are the only tried and stable versions of Nero. I can come up with some links for those versions if you need them.
I've burned lots of music to DVD with Nero and never had an ounce of trouble, except when I used junk (*cough*Ritek*cough*Memorex*cough*CMC*cough*TDK*.. ahem, excuse me) media. -
Well I just downloaded CDBurnerXP Pro myself and used it to burn two CD-R discs ... source: MP3 files ... destination: a standard redbook audio CD-R ... and it seemed to work well.
It also supports data CD-R and data DVD-R so I like the program so far ... anything that works for burning that isn't NERO is A-OK in my book :P
I think I found my new burning application except of course for DVD Video burning where ImgBurn is still king.
^^right i tried that just now it managed to go further than nero but failed @round 80some percent,i tried one more time and i again got the blue screen about halfway in....it reads kernel_data_inpage_error prog seems dandy not sure what is the problem,with a mention of dicsc im thinkin it could be that mine arent top of the line or anything standard comp usa, hp.
[quote="CrayonEater"]Are you certain you are burning with Nero Burning ROM purely as data? I've never heard of a BSOD occurring in this manner.
/quote]
actually it's nero express im burning with. i got it from the start up menu under data dvd,and now i think of it i always use nero "burning rom" for burning playable dvds and it usually works - but where is the data-dvd option? i might give that shot -
When you start Burning Rom, a DVD-ROM is the default compilation type. Just click it and go.
If that doesn't help, try posting your Nero log. It's in c:\Program Files\Nero\Nero 7\core\nerohistory.log. Might be Nero 6 if you are using Nero 6.
Backing up HD DVD
By captainzog in forum Newbie / General discussionsReplies: 13Last Post: 21st Oct 2011, 09:49 -
Backing up a DVD
By kschwi in forum DVD RippingReplies: 19Last Post: 29th Nov 2009, 09:15 -
Replace Background Music with New Music without affecting other tracks
By PaulDHolloway in forum AudioReplies: 3Last Post: 10th Apr 2008, 12:56 -
How To Rip and Manage Music DVDs just like Music CDs in JRiver Media Center
By jmone in forum User guidesReplies: 0Last Post: 13th Oct 2007, 18:15 -
Can I burn a music video along with music trax onto the same disc?
By Kalla B in forum Newbie / General discussionsReplies: 0Last Post: 4th Jul 2007, 12:02
