When watching TV on my PC using AverTV Studio I can see vertical noise lines. This does not seem to be a weak signal problem, but an interference problem. I tested an older Pinnacle PCTV Rave card on the same PC and I could see the same thing, so it's not a card-specific problem. I also tried a different cable/antenna and again I had the same issue. Moving the TV card in a different PCI slot also did not help. Anyone has any ideas on how I could solve this problem?
Results 1 to 1 of 1
vhs with vertical lines
By spiritgumm in forum Video ConversionReplies: 29Last Post: 22nd Aug 2019, 09:17 -
Vertical lines in SD camcorder video ?
By Umen Pich in forum EditingReplies: 8Last Post: 21st Dec 2011, 19:25 -
Bizarre vertical lines
By Asterra in forum Capturing and VCRReplies: 55Last Post: 17th Apr 2011, 21:46 -
Vertical Lines Appearing On Capture
By XBucklawX in forum Capturing and VCRReplies: 0Last Post: 26th Jun 2007, 11:11 -
vertical lines in 2.5
By thekingbeyond in forum SVCD2DVD & VOB2MPGReplies: 28Last Post: 23rd Jun 2007, 14:53
