Hi,
I have a avi file about 730MB but i need to reduce that file about 50/60MB to put in a DVD thogether with other files and to fit all in one dvd i need to reduce the size of one of them.
How can i do that, i just want to reduce about 50/60MB of size of avi.
I now that it problaby it can be done with virtual dub but i dont now how to.
Ab«ny one can help me?
Tks
Easiest route would be to use AutoGK (which in turn uses VirtualDub IIRC) and set the output file size to suit your needs.
/Mats -
Or make the needed adjustments during your mpeg conversion for dvd authoring.
Google is your Friend -
Thank You, it works fineOriginally Posted by mats.hogberg
That was the easiest way to reduce the size of a avi file, that is not the fastest but it sure the easiest.
For the result i have looking for it works exelent.
Once again thank you -
It sounds more like the OP is looking to do a data DVD, not video DVD..
Perhaps you can do a direct stream copy and cut the end credits and/or intro to achieve the size you want?
Load file -> Make sure Video>Direct stream copy is set -> Set mark in/Mark out points -> File>Save as.. and done..If it's a feature length film (or similar) with the usual long-ish end credits, you can probably kill that and not have to recompress - hence further reducing the video quality. -
If there's problem fitting x minutes of video as AVI on a disc, it sure wont fit when converted to Video DVD compliant mpg (at any reasonable quality level).
/Mats
Reduce file size .
By pensioner in forum Newbie / General discussionsReplies: 4Last Post: 10th Dec 2010, 15:08 -
Reduce file size
By windranger in forum Newbie / General discussionsReplies: 1Last Post: 13th Aug 2010, 10:18 -
Reduce AVi file size
By froggger in forum Newbie / General discussionsReplies: 7Last Post: 9th Feb 2009, 17:58 -
Reencoding to reduce the file size of an AVI (xvid) file
By DVantrease in forum Video ConversionReplies: 7Last Post: 10th Jan 2009, 21:56 -
How can I reduce the file size of an XVID AVI without re-doing it?
By nic2k4 in forum Video ConversionReplies: 2Last Post: 20th May 2008, 15:05
