    Oct 2006
    Slovakia
    I recently captured a home video (I used VirtualDub). It is a large file (cca 13GB) - it is long 60 min. Today I wanted to view this video and I found out, that audio plays only cca 20 minutes and not more.
    Any ideas, what can it be?
    Oct 2006
    Slovakia
    Can be the problem with non-compressed audio (PCM) in captured video? Can it be so long (about 1 hour)?
  3. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Open the video in Virtualdub and click on file -> file information (or similar). Look at the running time of the video and the audio. If they are the same (or within a millisecond or two of each other) then you have all the audio, but you may have a corruption in the file.
    Read my blog here.
    Oct 2006
    Slovakia
    no, audio length is 18 min and 56,7 sec. After this point there is no audio
  5. Member Soopafresh's Avatar
    Jan 2004
    You are probably S.O.L
  6. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Yep. It looks like you are missing two thirds of the audio - from the 18 minute mark onwards. Looks like you will have to capture it again.
    Read my blog here.
    Oct 2006
    Slovakia
    Recently, I hava defrahmented the disk partition, whre is stored this video and it freezed for a long time, but then was it ok... Could this corrupt the file?
  8. Not likely. It probably "freezed" (apparently) due to having to move such a large file (13GB) as part of it's defragmenting process.
