Hi,
I'm trying to create a DVD which contains only Audio.
I have 25 podcasts of one hour with a total of 3,6gB
With DLP2 I was able to make Audio-Only titles.
I made 25 movies containing the audio.
Made 3 menu's:
Root1: selection #1 - #10
Root2: selection #11 - #20
Root3: selection #21 - #25
First play and Title button are set to Root 1.
And root 1 links to root 2, root 2 links to root1 and 3 and root 3 links to root 1 and 2.
In the debug it runs perfectly.. can enter each movie on the dvd and go back to the menu..
When I start compiling, it only takes a minute before it says it's done.
And my folders show a vts.bin file of 20mb, Video_ts: VTS.PGC (6kb) VTS_01_1.vob (238mb) and then VTS_01_2.vob till VTS_01_9.vob are all 0 bytes.
What's happening???
Would appreciate a solution..
Results 1 to 15 of 15
Upgraded to latest dlp2 2.19?
And ask in http://www.mmbforums.com/phpbb/viewforum.php?f=24 also. -
all ac3 files...
podcasts are originally m4a files..
i let i-tunes convert them to aac files, then converted them to mp3 files with Xilisoft Audio Convertor and then
let dbPowerAmp converted them to wave files with ac3 conversion.
When importing them into DLP, it asked to write another header, so it made an ac3 format of it...
But strange thing was, in version 1.6 it was compiling and muxing for 17min.
In that version I made it with menu's which contained the audio-tracks.. only got a conversion error after a few attempts, cause
I made some beginner errors with the menu's..
But with the release of 2.0 I wanted to use the Audio-Only thing... but now my old project with all the menu's doesn't compile either..
So think it's a problem of this 2.x version -
I haven't had any problems, but I create my AC3 files using the certified encoder from Sony. DLP can be very picky about the quality of source, especially ac3. The fact that DLP whats to re-write the header make me suspicious of the source. Also, I would skip the mp3 step and save as uncompressed wav. They are already compressed enough without throwing in the indiginty of mp3 as well.
Try convert a few with ffmpeggui to see if they compile.Read my blog here.
Originally Posted by guns1inger
Still not working..
replaced all audio with new AC3 files...
and removed all images from backgrounds etc.
the report:
* VMG Verification *
Number of VTS - 1
Number of Menus: 1
Menu 01 - Type - Dummy
Number of imported VTS: 0
* VTS Verification *
<<< VTS Number 1 >>>
Number of Titles: 25
Title 01 - Type - Slide
Segment 1, Image File G:\DVDLab\temp\101283552_tmp0.bmp
Picture size - 720 x 576
Segment 1, Audio File E:\Audio\Podcasts\AC3\1. Deep Dish.ac3
Audio type: AC3_Mot, Channel: 2, Sampling: 48000, Bitrate: 320000
Title 02 - Type - Slide
Segment 1, Image File G:\DVDLab\temp\196206512_tmp0.bmp
Segment 1, Audio File E:\Audio\Podcasts\AC3\2. Erick Morillo.ac3
Title 03 - Type - Slide
Segment 1, Image File G:\DVDLab\temp\100838800_tmp0.bmp
Segment 1, Audio File E:\Audio\Podcasts\AC3\3. Benny Benassi.ac3
Title 04 - Type - Slide
Segment 1, Image File G:\DVDLab\temp\196468576_tmp0.bmp
Segment 1, Audio File E:\Audio\Podcasts\AC3\4. Armin van Buuren.ac3
Title 05 - Type - Slide
Segment 1, Image File G:\DVDLab\temp\54640632_tmp0.bmp
Segment 1, Audio File E:\Audio\Podcasts\AC3\5. David Guetta.ac3
Title 06 - Type - Slide
Segment 1, Image File G:\DVDLab\temp\100614152_tmp0.bmp
Segment 1, Audio File E:\Audio\Podcasts\AC3\6. Sharam Jey.ac3
Title 07 - Type - Slide
Segment 1, Image File G:\DVDLab\temp\101289992_tmp0.bmp
Segment 1, Audio File E:\Audio\Podcasts\AC3\7. Nic Fianculli.ac3
Title 08 - Type - Slide
Segment 1, Image File G:\DVDLab\temp\102051848_tmp0.bmp
Segment 1, Audio File E:\Audio\Podcasts\AC3\8. M.A.N.D.Y..ac3
Title 09 - Type - Slide
Segment 1, Image File G:\DVDLab\temp\196621472_tmp0.bmp
Segment 1, Audio File E:\Audio\Podcasts\AC3\9. Axwell.ac3
Title 10 - Type - Slide
Segment 1, Image File G:\DVDLab\temp\198875160_tmp0.bmp
Segment 1, Audio File E:\Audio\Podcasts\AC3\10. Tom Novy.ac3
Title 11 - Type - Slide
Segment 1, Image File G:\DVDLab\temp\54816608_tmp0.bmp
Segment 1, Audio File E:\Audio\Podcasts\AC3\11. DJ T.ac3
Title 12 - Type - Slide
Segment 1, Image File G:\DVDLab\temp\100515256_tmp0.bmp
Segment 1, Audio File E:\Audio\Podcasts\AC3\12. King Unique.ac3
Title 13 - Type - Slide
Segment 1, Image File G:\DVDLab\temp\54981680_tmp0.bmp
Segment 1, Audio File E:\Audio\Podcasts\AC3\13. Gabriel & Dresden.ac3
Title 14 - Type - Slide
Segment 1, Image File G:\DVDLab\temp\195387400_tmp0.bmp
Segment 1, Audio File E:\Audio\Podcasts\AC3\14. Armand van Helden.ac3
Title 15 - Type - Slide
Segment 1, Image File G:\DVDLab\temp\100594696_tmp0.bmp
Segment 1, Audio File E:\Audio\Podcasts\AC3\15. Trentemoller.ac3
Title 16 - Type - Slide
Segment 1, Image File G:\DVDLab\temp\197021704_tmp0.bmp
Segment 1, Audio File E:\Audio\Podcasts\AC3\16. Ferry Corsten.ac3
Title 17 - Type - Slide
Segment 1, Image File G:\DVDLab\temp\195533944_tmp0.bmp
Segment 1, Audio File E:\Audio\Podcasts\AC3\17. Kraak en Smaak.ac3
Title 18 - Type - Slide
Segment 1, Image File G:\DVDLab\temp\54830520_tmp0.bmp
Segment 1, Audio File E:\Audio\Podcasts\AC3\18. Markus Schulz.ac3
Title 19 - Type - Slide
Segment 1, Image File G:\DVDLab\temp\198381056_tmp0.bmp
Segment 1, Audio File E:\Audio\Podcasts\AC3\19. Bob Sinclar.ac3
Title 20 - Type - Slide
Segment 1, Image File G:\DVDLab\temp\195805192_tmp0.bmp
Segment 1, Audio File E:\Audio\Podcasts\AC3\20. Mark Spoon.ac3
Title 21 - Type - Slide
Segment 1, Image File G:\DVDLab\temp\102044840_tmp0.bmp
Segment 1, Audio File E:\Audio\Podcasts\AC3\21. Tiga.ac3
Title 22 - Type - Slide
Segment 1, Image File G:\DVDLab\temp\102003288_tmp0.bmp
Segment 1, Audio File E:\Audio\Podcasts\AC3\22. Cassius.ac3
Title 23 - Type - Slide
Segment 1, Image File G:\DVDLab\temp\195621216_tmp0.bmp
Segment 1, Audio File E:\Audio\Podcasts\AC3\23. Danny Howells.ac3
Title 24 - Type - Slide
Segment 1, Image File G:\DVDLab\temp\100914896_tmp0.bmp
Segment 1, Audio File E:\Audio\Podcasts\AC3\24. Soulwax.ac3
Title 25 - Type - Slide
Segment 1, Image File G:\DVDLab\temp\100920376_tmp0.bmp
Segment 1, Audio File E:\Audio\Podcasts\AC3\25. The Scumfrog.ac3
Number of Menus: 4
Menu 02 - Type - Still
nMenu cell count - 1
Menu Image File G:\DVDLab\temp\102227888_tmp1.bmp
Menu Audio File - None
Menu Sub-Picture File G:\DVDLab\temp\102227888_tmpsub1.bmp
Menu 03 - Type - Still
Menu Image File G:\DVDLab\temp\198234352_tmp1.bmp
Menu Sub-Picture File G:\DVDLab\temp\198234352_tmpsub1.bmp
Menu 04 - Type - Still
Menu Image File G:\DVDLab\temp\55285416_tmp1.bmp
Menu Sub-Picture File G:\DVDLab\temp\55285416_tmpsub1.bmp
* Status Messages *
Start building Video Title Set ( VTS ) ... - 2001
Title - 1
Start building slide title is in process ... - 2400
Initializing audio packets ... - 3005
Initializing AC3 (MOT) audio packet ... - 3030
Encoding bitmap and building VOBU is in process ... - 2450 -
made new ac3 files.. same problem..
1 file works.. but more movies.. no success!
tried now the same with importing WAV files into DLP.
error because of the 44,1kHz.
Used Quick-lab MPEG Encoder to convert them to MP2 files...
1 Movie > Works
More Movies > Same error :S
No menu's, only 2 movies (audio-only)
report:
Number of VTS - 1
Number of Menus: 1
Number of Titles: 2
Segment 1, Image File G:\DVDLab\temp\54784896_tmp0.bmp
Segment 1, Audio File E:\Audio\Podcasts\wave\1. Deep Dish.mp2
Audio type: MPEG, Channel: 2, Sampling: 48000, Bitrate: 320000
Segment 1, Image File G:\DVDLab\temp\54816672_tmp0.bmp
Segment 1, Audio File E:\Audio\Podcasts\wave\2. Erick Morillo.mp2
Number of Menus: 1
* Status Messages *
Title - 1
Initializing MPEG 1 audio packet ... - 3020
Audio packetizing ends - 3025
Creating PGC for the title is in process ... - 2500
Title - 2
Think it has to be a bug somewhere in the program..
Can't find anything else.. -
Skiloem,
here is a link to user guide in this forum I've written for an audio-only dvd containing up to 50 albums.
https://forum.videohelp.com/viewtopic.php?p=1517751&highlight=audioonly#1517751
Hope this helps,
Kardargo -
Finally did the job...
The problem of rendering was, that I only could use 8 Audio-Only Movies in 1 VTS.
So I made 3 different VTS compilations and put these as one into a complete Compilation.
That did the job!
Thanks for all help!
Creating video from images WITH audio
By boyer in forum Video ConversionReplies: 13Last Post: 3rd Mar 2012, 02:01 -
creating an audio track for a custom DVD.
By fred3f in forum Authoring (DVD)Replies: 12Last Post: 15th Sep 2011, 05:42 -
Creating audio DVD advice please
By ozbrit in forum AudioReplies: 5Last Post: 5th Jan 2011, 08:36 -
audio sync problem creating DVD from AVI files
By EtherJones in forum Authoring (DVD)Replies: 2Last Post: 8th Jun 2010, 10:12 -
Creating a DVD from a MKV file and retaining all the audio tracks
By TioSolid in forum Video ConversionReplies: 7Last Post: 8th Aug 2008, 07:06
