After a fresh reinstall of my OS and applications I noticed a high CPU usage by windows explorer when playing any mpeg2 file. CPU usage continued even after stopping the playback, and required me to manually stop the explorer process through windows’ task manager. After using the application “Process Explorer” I was able to isolate the file lmpgspl.ax as the culprit of the anomalous CPU usage, that file is located in: C:/program files/common files/ulead systems/Mpeg, once I renamed the file to .bak the problem stopped, but now TMPGenc can not open mpeg2 files unless I enable the lmpgspl.ax by removing the .bak extension.
Sound like this is the MPEG-2 codec your system is using, and it is damaged or something.. try uninstalling it with codec sniper, then install a new MPEG-2 codec, like Stinkys MPEG2 Codec.
You are in breach of the forum rules and are being banned. Do not post false information.
/Moderator John Q. Publik
Encode for lowest CPU load while playing in Windows Media Player
By IriTrisha in forum Video ConversionReplies: 8Last Post: 15th Apr 2012, 11:23 -
vdub - bad PCM audio capture after fresh install of huffyuv
By wolfdogg in forum Video ConversionReplies: 1Last Post: 11th May 2011, 01:45 -
playing HD video with a $20 cpu and a $30 GPU with Linux
By deadrats in forum LinuxReplies: 1Last Post: 11th Dec 2008, 12:01 -
convert hd pal mpeg2 file to hd ntsc mpeg2 file
By gearo in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 5th Jun 2008, 02:12 -
Codecs - Which to install on fresh OS?
By acommuter in forum Newbie / General discussionsReplies: 9Last Post: 7th Jul 2007, 17:39
