I was wondering i have a program that will take vob files and merge them together to make a movie. I have iso files right now and if i extract the files using winrar then i see there are vob files. Can i just simply take these files. Or is their other things that i need to worry about. Also I used dvdshrink to extract clips and it saves the clips as iso. That is the iso clips i have now.
If you have the VOBs and the rest of the DVD format, you already have a DVD movie. See 'WHAT IS' DVD to the upper left. <<<<<<
But it you want to extract the MPEGs from the VOBS you can use VOB2MPG. This will give you one large MPEG of the entire movie. You can also do this with TMPGEnc encoder or you can open the individual VOBs with a program like VirtualDub Mod and convert them to Xvid or similar formats.
MAKING SRT FILE FROM IDX and SUB after EXTRACTION FROM A DVD USING AVIDEMUX
By montejohn in forum SubtitleReplies: 1Last Post: 4th Mar 2012, 16:47 -
Batch extraction of audio streams from mpg/vob?
By gaikokujinkyofusho in forum AudioReplies: 1Last Post: 4th Dec 2010, 04:15 -
MKV chapter file extraction problems
By ikarishinji41 in forum EditingReplies: 1Last Post: 22nd Mar 2010, 11:03 -
Dummy VOB, full disk extraction...cannot be done
By sknox in forum MacReplies: 11Last Post: 9th Oct 2007, 21:36 -
extraction of image frames from MJPEG file
By vivian in forum Video ConversionReplies: 2Last Post: 3rd Oct 2007, 04:21
