if i have an mp3, is there a way i can strip the instrumental from the accapella, and with what software can i do this with (please name so i can buy)...if there is a scheaper way to do this please inform me..
"If u cant eat it - u dont need it"
"Baby - If i dont hit it, Who will?"
"Why is Abbreviation such a long word"? -
Main Entry: a cap·pel·la
Variant(s): also a ca·pel·la /"ä-k&-'pe-l&/
Function: adverb or adjective
Etymology: Italian a cappella in chapel style
: without instrumental accompaniment -
If you mean remove the vocal from the instrumental (or vice versa) then the answer is........no.
"Art is making something out of nothing and selling it." - Frank Zappa -
jagabo - you pedatic bastard
There are tools that can reduce the vocal on a track, however they only work with high quality professional recordings where the instruments are recorded in the left and right channels, and the vocal are recorded straight down the middle. They strip anything that is evenly recorded in both channels through phase inversion. The problem with most recordings is that the vocal are treated with reverb or chorus effects that are no symetrical, so these get left behind. To make matters worse, you have specified MP3 as the source. MP3 compression screws the phase and muddies the stereo field, rendering it useless for this type of work.
If you want to play, have a look at AnalogX's vocal remover. There is a free DirectX version for Sound Forge and similar editors, and a WinAMP version.Read my blog here.
Header stripping
By NikkiSix in forum Newbie / General discussionsReplies: 46Last Post: 17th Feb 2013, 17:57 -
Stripping from audio, but with a twist.
By Diana (Cda) in forum AudioReplies: 2Last Post: 12th Jun 2010, 14:56 -
Stripping away audio tracks
By Belfaborac in forum Video ConversionReplies: 2Last Post: 19th Feb 2009, 11:06 -
stripping audio
By lou41888 in forum AudioReplies: 7Last Post: 5th Nov 2008, 18:46 -
file size after stripping audio from DV
By dADDo in forum AudioReplies: 6Last Post: 10th Mar 2008, 22:58
