I seem to recall that there's some advanced setting you can change before burning on Windows to make DVD+R's much more compatible with DVD players. Is there a way to do that on a Mac?
If your burner has a modified firmware that allows bitsetting ..... (you can change the booktype from DVD+R to DVD-ROM). This makes the DVD+R more compatible with older players. Newer DVD players should be able to play +R or -R equally as well.
So do I just need a firmware modification, or do I also need software that will allow me to do it (and is there any available for Mac)? And where would I find this? My burner model is DRW-3S163, btw.
All you need is a mod firmware. It looks like you would have to crossflash the burner to a LiteOn. Check out this forum:
http://club.cdfreaks.com/showthread.php?t=136823
To get it to work on a Mac try here:
http://forum.rpc1.org/viewforum.php?f=30&topicdays=0&start=90
Maybe you you should upgrade your burner ... They are pretty cheap. NEC's have Mac support and have plenty of mod firmware.
K-Lite Codec Pack messing up burning IMG audio cd burning
By Blå_Mocka in forum AudioReplies: 24Last Post: 26th Aug 2010, 06:27 -
1. Need advice: Burning DVD from Flash Drive mP4 2. DVD-R vs. DVD+R
By Ronald Vaughan in forum Newbie / General discussionsReplies: 1Last Post: 14th Jul 2010, 15:53 -
Iso burning faile, folder burning succeed
By cd090580 in forum DVD & Blu-ray WritersReplies: 5Last Post: 3rd Dec 2009, 15:46 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14 -
Advantages - disadvantages to burning video folders or burning an ISO img
By theewizard in forum Authoring (DVD)Replies: 14Last Post: 26th Jun 2007, 16:19
