have a problem with dvd writer. it stopped working..movies will not burn..getting error such as drive not ready can not perform disk end at once..those errors happen with nero..used arcsoft showbix and says it burned successfully but nothing burn on disk..can some one help me solve the problem???? i have the latest firware contacted hp and nero and no help..was working fine till a couple months ago...also changed mode to dma and nothing i do is working running out of resources
Is it able to read discs (cd and dvd)? If it can't, then you most likely have a hardware issue. Probably a bad drive. From the information you provided above, it sounds like a bad drive.
Google is your Friend -
HP dc3000 has upgrades available for the Arcsoft Showbiz software, and firmware upgrades for the device. Mine didn't work until I installed both. Now works well. They can be found at:
http://h10025.www1.hp.com/ewfrf/wc/softwareList?lc=en&cc=us&dlc=en&product=327406&lang=en&os=228
and
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?lc=en&cc=us&dlc=en&os=228&pro...tem=dv-22067-1
Hope this helps.
Multisession DVD Burner and Burning Files into Specific Folders
By Disco Makberto in forum ComputerReplies: 9Last Post: 23rd Feb 2010, 02:48 -
dvd Burner crapping out while burning DL disc, need help
By mazinz in forum DVD RippingReplies: 7Last Post: 21st Jan 2009, 18:38 -
Trouble burning DVD+R DL with Pioneer burner
By RoyGBiv-inRI in forum DVD RippingReplies: 11Last Post: 17th Oct 2007, 11:43 -
burning dvds without dvd burner??
By lordscrubba in forum Newbie / General discussionsReplies: 6Last Post: 19th Jun 2007, 10:19 -
DVD-ROM to DVD Burner Direct Burning
By Wilson7777 in forum DVD RippingReplies: 6Last Post: 15th Jun 2007, 12:37
