    Sep 2006
    In another forum there was a discussion about the Phillips DVP-642 and how some Xvid or Divx files don't playback correctly:
    "In short, compared to the ESS-powered DVP-642, the Mediatek-powered DVP-5140 appears to be a much, much more capable unit. Gone are the problems with QPEL and files encoded with custom quant. matrices (the files where you had to hit 'SYSTEM' twice to get the colors to appear correctly). "
    I used GK to convert some MEPG-2 files with success, but I have that problem described above on playback. While not really a show-stopper, it is annoying. My question is: is there a setting in GK that will make the resulting Xvid (I'm not using Divx option) not have this display problem? I have the AutoGK Assistant, but pretty much left it alone as I don't understand all of those settings.
    Relayerman
    Dec 2004
    Australia
    For a DVP-642 use the ESS option in AutoGK.
    Sep 2006
    Alright, thanks. I will try that.
