    Oct 2006
    I have two dvd players at home ,one will play all my downloaded dvd's but the other one won't ,I looked in the dvd hacks for it but it don't there and when I went to put the name and number for it ,it said that I needed a url I can't find it anywhere I bought it at Walmart about 3yrs ago Did any one have that problem or do you know where I can get the hack for it Thanks
    mjc
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    What error do you get when trying to play the discs?
    If you are getting a "no disc" error, then you will need to use a different type/brand of media.
    If you are getting a "incorrect region" or similar message, then you will need a region hack if one is available.
    Google is your Friend
    Oct 2006
    it says play is unavailable cause no disk is loaded,and when I put in the 2 dvd's that do work in it there is no sound this player is a rca drc212 ,the other dvd player that works is a klh and the number is kd-1220,Im using imation dvd's to burn ,so do you think it could be the dvd's that Im using or does the rca need a code for the region?
    mjc
    Oct 2006
    I have a sony disk I could try
    mjc
