I am having video problem. I have a problem with these files, from VIDEO TS folder VTS_01_0.VOB VTS_01_0.BUP, they are blank, not all of them just 2-4 files.
I use, Shrink3.2, dycriptor, clone w/dvd43, and have tried many codec’s also to try and resolve this problem CCCP, FFdshow, WinDVD7, gspot, mpeg2codec, VLC, WinAVI, and the list goes on, some left me confused. I mainly use Shrink, dycriptor, Nero 6, Clone W/dvd43, no problems. Nothing will open & play these files.
I use an amd 2400 256 ram w/ 2-40gig ide hard drives, 64mb gforce 2 video card. I have a sata slot on my board. I plugged in a sata hard drive into my board (I have a sata board) to re-install operating sys, when I switched hard drives back to my ide, I’ve had these problems since. What I get out of all of this is mpeg2 files, SVCD/DVD, needs a codec. I’ve tried changing MOBO’s settings and numerous fresh installs of XP PRO & different ide hard drives. I’ve also tried taking out the battery of the MOBO. It seems like something changed a MOBO setting when the sata was installed & the MOBO needs flashed (so I’ve been told, not sure how to do it). Any suggestions?
I get this message from FFdshow C:\\VIDEO_TS\VTS_01_5.VOB
File : 1023 MB (0.00 B), duration: 0:00:00, type: MPG, 3 audio stream(s), quality: 83 %
Video : 0.00 B, 9800 Kbps, 29.970 fps, 720*480 (4:3), MPG2 = MPEG 2 (SVCD/DVD), Supported
Audio : 0.00 B, 448 Kbps, 48000 Hz, 5 channels, 0x2000 = AC3 DVM [0x80], Supported
Audio : 0.00 B, 384 Kbps, 48000 Hz, 5 channels, 0x2000 = AC3 DVM [0x81], Supported
Audio : 0.00 B, 192 Kbps, 48000 Hz, 2 channels, 0x2000 = AC3 DVM [0x82], Supported
D:\VIDEO_TS\VIDEO_TS.VOB
File : 362 KB (0.00 B), duration: 0:00:00, type: MPG, 0 audio stream(s), quality: 73 %
Video : 361 KB, 4587 Kbps, 29.970 fps, 720*480 (4:3), MPG2 = MPEG 2 (SVCD/DVD), Supported
C:\ \VIDEO_TS\VTS_01_7.VOB
D:\VIDEO_TS\VTS_01_1.VOB
File : 10.00 KB (0.00 B), duration: 0:00:00, type: MPG, 0 audio stream(s), quality: 73 %
Video : 9.99 KB, 4587 Kbps, 29.970 fps, 720*480 (4:3), MPG2 = MPEG 2 (SVCD/DVD), Supported
Results 1 to 1 of 1
Need to make IFO, BUP for Single VOB
By Simmons in forum Authoring (DVD)Replies: 5Last Post: 28th Aug 2011, 21:15 -
Burn VOB without BUP IFO [Special]
By ron007 in forum Authoring (DVD)Replies: 1Last Post: 16th Feb 2009, 21:01 -
How to play a .vob .bup .ifo files?
By Kinstonian in forum Software PlayingReplies: 12Last Post: 19th Mar 2008, 17:26 -
FAVC - Missing VIDEO_TS.bup, VTS_01_0, VTS_01_0.BUP, VIDEO_TS (.vob)
By Brent.M in forum Newbie / General discussionsReplies: 14Last Post: 8th Feb 2008, 08:47 -
VOB/BUP/IFO to AVI???
By chronic777 in forum DVD RippingReplies: 6Last Post: 11th Aug 2007, 13:10
