When i play movies in my NERO 7.5.1.1 premium showtime..........the videos become distorted....it is like water spilled over the monitor..,...i get those kind of images when i play the movie......
What format are your videos that have the problem? I would try the freeware VLC media player and see if it does the same thing. If so, that would point to Showtime as the problem or the codecs it is using. If not, it may be something wrong with the videos.
I hope you haven't installed any codec packs, that's a fairly common cause of playback problems. VLC uses it's own codecs so is a good test for codec problems.
Can't read Dvd, just with Nero Showtime
By sunco in forum Newbie / General discussionsReplies: 6Last Post: 17th Sep 2008, 01:31 -
Nero Showtime 4 Freezes When Capturing A Frame
By sbpyper in forum Capturing and VCRReplies: 0Last Post: 10th Jul 2008, 05:56 -
How do I install Nero Showtime and only that?
By fk in forum Software PlayingReplies: 0Last Post: 16th Apr 2008, 04:17 -
How to remove Nero Showtime only
By lordmajax in forum Software PlayingReplies: 4Last Post: 8th Aug 2007, 18:46 -
Nero Showtime playing from network folder ?
By Ian Huxley in forum Software PlayingReplies: 1Last Post: 1st Jun 2007, 13:40
