I have an AVI file which plays fine on my computer.
I am trying to convert it to DVD format, but TMPGenc, DIKO, GSpot won't even begin to start with it, throwing up error messages:
DIKO = 10:13:20: DIKO was not able to open one movie file. This error generally happens when the source movie is read-only, which is very commom when you copy a movie from a CD. Please remove the read-only attibute and try again.
TMPGenc = File "...." can not open or unsupported.
GSpot = The filename, directory name, or volume label syntax is incorrect.
I have used Virtualdub to try to sort this out (after looking in your forums for "problem avi's), and that had no effect on the avi.
Like I said, the avi plays fine on the computer, but there mist be something missing somewhere!
Any help gratefully received!
Ian
In addition, when I open the folder where the avi is stored, I get this weird graph thing called "AVI Chunks" .... Yoikes!
There seems to be a problem with the file name and attributes.
Many programs require a simple name, no funny characters, not too long.
Open an Explorer window on the folder where the file is, right click on the file icon, choose "Properties".
Uncheck "read only" if that's marked.
Rename it to something short and simple, like "video1.avi"
Similarly for the folder name. -
Yes, try & see is always a good approach. Even if it fails, you may learn something!Originally Posted by CaptainChaos
Or maybe even better - try loading it in VirtualDub, and save out a new version of it, using Direct Stream for both audio & video. That ought to take care of the potential interleave problem.
/Mats
I cannot open an AVI file in SONY VEGAS 10... it says I need a codec?
By daniel827 in forum EditingReplies: 1Last Post: 25th Oct 2011, 10:09 -
virtuldub can not open avi file?
By wuqingshi in forum EditingReplies: 6Last Post: 1st Sep 2011, 20:40 -
Can't open MKV file ripped from DVD - Plays in VLC but not in edit programs
By dsunbury in forum DVD RippingReplies: 3Last Post: 7th Apr 2011, 05:21 -
avidemux won't open a DV .avi file
By BrianK in forum Video ConversionReplies: 2Last Post: 14th Jul 2009, 10:10 -
cannot open avi file
By ione in forum Capturing and VCRReplies: 8Last Post: 14th Sep 2008, 21:02
