ok. i hav used virtualdub before and it worked but somehow it seems i'm miss a file of some sort and i can't find it. when i try to open a file it says that format 'XVID' (unknown). then it says 'virtualdub requires VFW' and so on... I hav ffdshow, divx 3.11 alpha, and the divx codecs 6. if anyone knows whats wrong plz be specific because i'm kinda new with all this ^^;; thanks!
It is telling you exactly what it needs. There are two main types of codec for displaying video. DirectShow is the current method, however the legacy method is Video For Windows, or vfw. Virtualdub requires vfw codecs. Download Koepi's Xvid codec from the tools section. It contains both DirectShow and vfw codecs.
You could also try changing the fourCC identifier to Divx, or enabling the Xvid vfw in FFDShow.Read my blog here.
thanks guns1inger! how do i change the fourCC to divx? does that mean i dont need ffdshow or i need it? i'm just starting to learn these things... -_-''
There is a program that does this. It might be called FourCC Changer. The FourCC is a tag that identifies the type of codec used to compresse the video. Xvid and Divx are very similar, and often can be ready by the oppposite codec if identified correctly. Have a look in the tools section for things associated with FourCC. When you find it, change it to Divx5 and try again.
Read my blog here.
VirtualDub being stupid (VFW codec...)
By Katsu-kohai in forum Video ConversionReplies: 20Last Post: 13th Jun 2017, 13:53 -
VirtualDub x64 with ffdshow vfw x64 no H264
By SandyB in forum Newbie / General discussionsReplies: 8Last Post: 10th Aug 2009, 18:45 -
vfw wrapper help
By video_2010 in forum Capturing and VCRReplies: 0Last Post: 21st Jul 2009, 15:48 -
ffdshow, vfw and x264
By Gigaplex in forum Newbie / General discussionsReplies: 6Last Post: 21st Oct 2008, 18:02 -
Where to get WDM to VFW wrapper
By SuperFlyBaconG in forum Capturing and VCRReplies: 1Last Post: 29th Jul 2007, 10:30
