Whenever I try to convert ANY video container type that has AAC as its input audio stream I get:
and Stream #0.1 looks like:Code:Unsupported codec (id=86018) for input stream #0.1
Here is my entire output (note I did compile with faad enabled)Code:Stream #0.1(eng): Audio: mp4a / 0x6134706D, 22050 Hz, stereo [10]
I heard there is something about aac support being pulled because of licensing? But I enabled faad so i'm assuming that isn't a problem?Code:Array ( [0] => FFmpeg version SVN-r6694, Copyright (c) 2000-2006 Fabrice Bellard, et al. [1] => configuration: --prefix=/usr --enable-mp3lame --enable-libogg --enable-vorbis --enable-faad --enable-faac --enable-xvid --enable-a52 --enable-dts --enable-pp --enable-shared --enable-gpl [2] => libavutil version: 49.0.1 [3] => libavcodec version: 51.20.0 [4] => libavformat version: 50.6.0 [5] => built on Oct 17 2006 03:23:04, gcc: 3.3.2 20031022 (Red Hat Linux 3.3.2-1) [6] => Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'videos/629475313.mp4': [7] => Duration: 00:00:07.9, start: 0.000000, bitrate: 1465 kb/s [8] => Stream #0.0(und): Video: h264, yuv420p, 320x240, 25.00 fps(r) [9] => Stream #0.1(und): Audio: mp4a / 0x6134706D, 22050 Hz, stereo [10] => Stream #0.2(und): Data: mp4s / 0x7334706D [11] => Stream #0.3(und): Data: mp4s / 0x7334706D [12] => Output #0, flv, to 'videos/629475313.flv': [13] => Stream #0.0: Video: flv, yuv420p, 320x240, q=2-31, 200 kb/s, 25.00 fps(c) [14] => Stream #0.1: Audio: mp3, 22050 Hz, mono, 64 kb/s [15] => Stream mapping: [16] => Stream #0.0 -> #0.0 [17] => Stream #0.1 -> #0.1 [18] => [flv @ 0x4042e008]removing common factors from framerate [19] => Unsupported codec (id=86018) for input stream #0.1 )
Results 1 to 11 of 11
Latest faad is actually 2.6beta. There were some bug fixes after the 2.5 release.
Can you watch the movie on your computer and hear the sound? It could be there's no supporting audio codec on your system.
Fixed.
I recompiled with latest faad (but in order to get it to compile I had to leave out faac lib).
Now I get audio (mp4 >flv) but it is VERY distorted. -
Try faad withouth drm and mpeg4ip enabled. Disable mp4v2 for faac and you should be able to link ok.
Celtic,
Is that faad with drm and mpeg4ip DISABLED. And mp4v2 for faac disabled?
Or did that first sentence mean drm disabled and mpeg4ip ENABLED?
Thanks for the clarification.
k -
./configure --disable-drm --disable-mpeg4ip
for faad although drm is disabled by default I think.
./configure --disable-mp4v2
for faac
If you want faad/faac frontends with mp4 handling, then compile them seperatly. Just that apps like ffmpeg that link with them have their own mp4 handling and having it enabled in faad/faac causes problems. -
Have same problem with
You have already solve the problem?Code:Unsupported codec (id=86018) for input stream #0.1
hi, i know this discussion is old, but i just had this problem with puppy linux 4.21.
there is good advice here:
http://www.murga-linux.com/puppy/viewtopic.php?p=295480
and i downloaded the new ffmpeg .pet file from here and all is working fine.
http://www.datafilehost.com/download-fd4708d5.html
how can i mux to mp4 from h264/aac using ffmpeg
By DKhanh in forum Video ConversionReplies: 3Last Post: 24th Aug 2013, 11:50 -
MKV AAC GUI Converter with Nero AAC Codec
By prijatelj.v in forum AudioReplies: 4Last Post: 26th Mar 2012, 08:41 -
ffmpeg error when encoding 6 channel aac
By BrianAtVH in forum AudioReplies: 5Last Post: 14th Feb 2012, 14:52 -
Unsupported codec (id = 0) in ffmpeg
By Nightslk in forum Video ConversionReplies: 3Last Post: 10th Nov 2009, 17:17 -
ConvertXToDVD, FFMpeg and AAC LC Audio
By Maikeru-sama in forum Authoring (DVD)Replies: 1Last Post: 10th May 2008, 20:28
