When I try burning a DVD ISO or an authored DVD movie, my drive takes anywhere from 35-60 minutes to burn a single 4.7gb disc! I am using 16x speed Verbatim DVD-Rs and burning at max speed. The software I've tried is Nero Ultimate 7 and Roxio Creator 8 Suite and both are equally poor in burn time. What's wrong?
Thanks!
I had similar problems before. Then I unplugged all cables and set everything to Cable Select mode : hard disks and dvd drives.
I changed the DVD drive to another IDE controller
Even now if I insert media in both my DVD-RW drive and DVD-R drive...my PC slows down 50%
is my defective board
Hi, Check to see if the DMA has been enabled....
Right click MY COMPUTER...
Goto HARDWARE>>>>>>>DEVICE MANAGER
Click on IDE ATA/ATAPI CONTROLLERS.
Right click on PRIMARY CHANNEL>>>>>PROPERTIES>>ADVANCED SETTINGS...
Check if TRANSFER MODE is set to DMA IF AVAILABLE.
Do that for DEVICE 0 and DEVICE 1.
Goto to SECONDARY IDE Channel and do the same....
Reboot computer and try again..
Good Luck...Have yer paid your dues Jack??
Yes Sir, the cheque is in the mail!!! -
thanks for your input - I've tried what you've suggested (it was enabled), so now I'm trying this out: http://winhlp.com/WxDMA.htm (source: https://forum.videohelp.com/viewtopic.php?p=1574764#1574764)
I don't need to burn anything right away and I don't want to waste potentially an hour of my time waiting to figure out whether it worked :P so I'm going to try to hunt down something I needed to burn anyway in the next few hours
thanks again -
And if DMA IF AVAILABLE is greyed out, then delete the Primary and Secondary channels, and reboot to let Windows re-install them.
Then the DMA IF AVAILABLE should be usable. Select it, and reboot again. -
YESSSSSSSSSSSS! this worked perfectly, I'm proud to report a 6-7 minute burn!Originally Posted by needhelpdvd
And it took no effort at all, just a download, double-click, and restart! AWESOME.
I have this problem on one computer, cannot burn faster than 4x. If I try 8x-16x, the burn takes 30 minutes (longer than 4x!). The POS VIA motherboard is the culprit. I just need to trash it sometime.
Playing British DVDs in USA - am I doing something wrong?
By newhaveninc in forum Video ConversionReplies: 4Last Post: 8th Apr 2012, 13:04 -
USB DVDs report wrong length with VOB2mpeg3
By mark pigott in forum SVCD2DVD & VOB2MPGReplies: 7Last Post: 25th Feb 2010, 04:09 -
DVDs burn fine, but Audio CDs only burn 1st half of songs right...
By Xenogear900 in forum Authoring (VCD/SVCD)Replies: 7Last Post: 28th Jan 2010, 05:26 -
Vista thinks dvds are wrong region...
By imaginaryduck in forum Software PlayingReplies: 8Last Post: 1st Oct 2009, 01:01 -
DVD Rom can burn DVDs but won't recognize burnt DVDs.
By soonie in forum DVD RippingReplies: 0Last Post: 23rd Aug 2009, 17:03
