Please help me with a program and instructions on how to convert a 7gb dual layer iso file into two single layer dvds. I dont need the original menu, just want to split the iso onto two burnable playable dvds. Thanks in advance!
Results 1 to 12 of 12
dvd shrink and use the reauthoring mode to cut the movie, http://www.dvdshrink.info/reauthor_basic.php .
If the ISO contains a dual layer Video DVD, mounting it with daemon tools and then continue as for any DVD9 -> 2 DVD5 project.
/Mats -
Could you elaborate a little more?Originally Posted by mats.hogberg
Not much to elaborate on. Mount the ISO with Daemon Tools. From then on, the ISO will for all apps be seen as a physical DVD in a DVD reader, and can be processed as such. Try this guide. (Should work without mounting the image too, but you say "doesn't work")
/Mats -
Doesnt work because, A: I didnt burn the DL iso file to disc because my burner wont do it properly and Dvd shrink doesnt reconigze iso files, at least my version doesnt. Ill try Dameon tools
Like I've said a couple of times: From now on, the mounted ISO will appear just as if you had a physical DVD inserted in your DVD reader (but with a different drive letter).
Just go ahead and do a DVD9->2xDVD5 backup. I gave you a link in my previous post to one guide. Take a look under DVD BACKUP for more.
/Mats -
Thank you. I was able to figure it out, mats and successfully burn it onto 2 dvds using Shrink after "mounting" it using that program. Here in the states we use that term to describe something else. Thanks again!
- I'm aware of other (not computer related) meanings of mounting too. Strange enough, I don't think there's any good Swedish translation for the computer "mount". (but quite a few for "something else").
Glad it worked!
/Mats
Multiple Titles In A DVD ISO To A Single AVI
By Simmons in forum Video ConversionReplies: 1Last Post: 9th Aug 2010, 01:32 -
Help Converting an ISO Image File into a DVD Format playable on DVD players
By Gradyj in forum Newbie / General discussionsReplies: 5Last Post: 19th May 2010, 21:13 -
Converting Multiple Chapter DVDs into one single MP4 file
By djfreex2 in forum Newbie / General discussionsReplies: 1Last Post: 12th Jul 2009, 14:02 -
how to convert iso to single layer dvd (4.7)
By roboroach in forum MediaReplies: 4Last Post: 1st Dec 2008, 13:44 -
converting an ISO file
By janefield in forum Video ConversionReplies: 2Last Post: 24th Jun 2007, 18:20
