Hi everyone,
Sorry if I am posting this in the wrong place. I have been hearing about HD VHS recorders
and players. Also states they will play analoge tapes as well.
My question is how accurate a statement is this. And could there really be good high def 720p
1080i quality from a high def program recorded to VHS tape?
If so I would really be interested in trying one out.
Anyone have any knowledge, links, or experience in this matter.
You would be really helping me out,
Thanks,
Steve
What is a HD VHS recorder?
Like ummm I don't think that exists so what are you talking about?
Hi,
Over on Amazon they have the JVC HMDH5U Digital VHS High-Definition Recorder.
Technical Details
* Digital VHS recorder archives high-definition, standard, and analog sources
* Connects to HDTV (1080i and 720p) through HDMI connector or component output
* Records up to 3.5 hours of HD content and 35 hours of analog content on single cassette
* 2 iLink terminals, component output, 2 S-video outputs and 1 input, and 2 AV inputs and 2 outputs
* 5.1 Dolby Digital/DTS optical output for multichannel soundtracks; MTS stereo
Here is the link to the page:
http://www.amazon.com/JVC-HMDH5U-Digital-High-Definition-Recorder/dp/tech-data/B0002J6...569539?ie=UTF8 -
Oh so you mean D-VHS ... this is for recording HDTV broadcasts ... but most HDTV is copy protected except for so-called "local channels". So you can record your local HD-ABC channel for instance but you can't copy any of the HD-HBO channels.
Anyways a D-VHS will only record in HDTV when the source is HDTV.
You can't take a non-HDTV source and copy it to HDTV. Any non-HDTV source will copy as VHS or S-VHS depending on the tape and the mode you have it in.
Mitsubishi has a D-VHS that can be bought brand new for around $200.00 but it does not have a HDTV tuner built-in so you would have to use a cable or satillite box that has FIREWIRE output.
The JVC seems to be about the same as the Mitsubishi but does seem to have more output options. I've been looking into the Mitsubishi and although it is unclear from what I've seen I think the Mitsubishi needs a HDTV with a FIREWIRE input whereas the JVC has component and HDMI outputs making it a bit more functional but at a higher cost.
Hi,
My HDTV has firewire outputs. Would that work? Also you said I would not be able to record HD Hbo does that mean HD Abc I can record would have to come from over the air thru anntena.
Thanks for the help..... -
I know the Mitsubishi (which can be bought for around $200.00) has FIREWIRE IN and FIREWIRE OUT so if your TV has BOTH of those inputs/outputs and a OTA tuner built in then you should be A-OK for local channels like CBS, ABC, NBC, FOX, etc.Originally Posted by ofield
Capturing VHS to PC with a high definition resolution...?
By dark_myuutwo in forum Capturing and VCRReplies: 108Last Post: 10th Jun 2016, 12:18 -
Old films to high definition?
By therock003 in forum RestorationReplies: 39Last Post: 1st Jan 2015, 09:27 -
High definition conversion
By kypreo in forum Video ConversionReplies: 10Last Post: 21st Mar 2010, 23:15 -
High Definition on DVD
By Dem Pyros in forum Authoring (Blu-ray)Replies: 24Last Post: 2nd Sep 2008, 09:48 -
video 8 to high definition
By devdev in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 10th Jan 2008, 14:31
