Results 1 to 30 of 53
    Sep 2006
    I accidently deleted a file that I need it, so I installed data recovery software in attempt to restore the file. I did it quickly and without any problems, however something came to my attention. I found thousands of files (all kinds of files that I deleted every since I can remember) that are just sitting there in the "back of my computer". Obviously those files has been deleted through Recycle Bin trash can, however they still remain somwhere in the computer. What is the purpose of that anyway and is there a way to ged rid of that garbage once for all?
    moved to another forum, nobody likes me here...
  2. Member daamon's Avatar
    Melbourne, Oz
    When a file is "deleted" and put in to the trash can, it's not really deleted it's just stored in a different place but still visible.
    When a file is "deleted" from the trash can, it's not really deleted - all that happens is the file is altered in a simple way such that:
    a) It can no longer be seen by Windows
    b) It no longer counts towards the space occupied on the drive
    c) It can be overwritten
    d) It can be retrieved by undoing the simple alteration.
    To truly delete a file (getting rid of your garbage) - i.e. to render it as if it never existed, you need something like Window Washer from Webroot Software.
    There are many other applications that do the same thing - some free, some more expensive. I use Window Washer and find it very good.
    There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
    Carpe diem.
    If you're not living on the edge, you're taking up too much room.
  3. I once wrote a simple program that just fills up the disc with a pattern of bytes. That will overwrite everything that has been deleted if you let it go until the drive is full.
    Sep 2006
    I see, but is there a free software that would do that or perhaps it can be done manually without a software
    Is this data still stored on a hard drive or somwhere else?
  5. Your question has been answered at least twice:
    "There are many other applications that do the same thing - some free, some more expensive. I use Window Washer and find it very good."
    "I once wrote a simple program that just fills up the disc with a pattern of bytes. That will overwrite everything that has been deleted if you let it go until the drive is full."
    Sep 2006
    Ok
    Apr 2004
    Miskatonic U
    I like eraser for cleaning up 'unused space'. It is free, and released through sourceforge. Main download links are here
    http://www.heidi.ie/eraser/download.php
    Read my blog here.
  8. Member daamon's Avatar
    Melbourne, Oz
    @ fLYtRap:
    There's a few websites that might help with your search:
    www.google.com
    www.download.com
    ...and similar.
    Carpe diem.
    Sep 2006
    Okay, I found a couple of software and I run scans and removals, but that didn't help.
    After that I run data recovery software and look what I found:
    This is what I want to remove, that washer didn't do it.
    Those are mostly temp files, images and internet or other shortcuts.
    They still remain in the computer beyond recycle bin trash can.
  10. Member daamon's Avatar
    Melbourne, Oz
    When you say "that washer" I'm going to presume you mean Window Washer. You really must be more specific...
    What settings did you have ticked? Ones like this:
    And what about the "Wash Items"?
    Carpe diem.
    Sep 2006
    okay now I'm recovering this image:
    Sep 2006
  13. Member daamon's Avatar
    Melbourne, Oz
    What tools?
    What settings?
    Be specific...!!!
    You might just have to bite the bullet and suffer trial & error...
    Carpe diem.
    Sep 2006
    and here is the recovered image, which one I'll delete once again to see where it goes....
    Sep 2006
    I tried again to wash and its still there. Only thing that changed is that now its in a poor condition.
    Sep 2006
    okay, here is main window of that washer...
    Sep 2006
    and here are system wash settings...
  18. Member
    Sep 2006
    and advanced...
  19. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    Off topic, but BMP files are a poor choice of format. For screenshots GIF is just as good, and the 1.1. MB BMP reduces to 60k as below. The forum software also displays it inline.
  20. Member daamon's Avatar
    Melbourne, Oz
    I'm not familiar that with software, but the screenshots seem to suggest that it's just a medium-level washer. You'll have to try others that go deeper - you may have to pay...
    Out of interest, what are you using to see what files are still on your hard drive? I'll use the same and see how well Window Washer cleans.
    Carpe diem.
    Sep 2006
    I got it
  22. Member
    Sep 2006
  23. Member
    Dec 2003
    Many years ago I read that files could be recovered from a hdd even after the data had be written over 7 times. I don't know what that number might be today but I would assume it is several times more. lol
    For the most part, a simple delete is plenty good enough. Even the word delete scares some people so bad they don't want to touch the keyboard.
    Good luck.
  24. Member
    Sep 2006
    Good luck.
    I have a program that I use when I do fresh install of windows which write zeros to drive wipeing out everything. This time I just want to do some cleanning in the "closet"
  25. Member
    Nov 2004
    Las Vegas
    fLYtRap,
    For what you're trying to do, you should get the freeware "Eraser" program that guns1inger provided the link to.
    There was a study done earlier this year that found that program to be as effective as any commercial or freeware program, and more effective than most. Unfortunately, the link to the study I had saved no longer works, and google can't find any trace of it. It would appear the study has been securely deleted.
    Since you are verifying your erasure tests with a tool you appear to trust, you should be able to check the results for yourself, which makes the study unnecessary anyway.
  26. Member daamon's Avatar
    Melbourne, Oz
    @ fLYtRap: I downloaded and tried out "PC Inspector" and got inconsistent results at best.
    I found that, on consecutives searches for deleted items, it would return varying results - with no deleting of files (or any action for that matter) in between searches. It didn't fill me with confidence that it is a reliable tool.
    Carpe diem.
  27. Member
    Sep 2006
    I found that, on consecutives searches for deleted items, it would return varying results - with no deleting of files (or any action for that matter) in between searches. it didn't fill me with confidence that it is an effective tool.
    That doesn't matter This thread is not about PC Inspector file recovery tool, it is about you know what...
  28. Member daamon's Avatar
    Melbourne, Oz
    True, but my reason for mentioning it was: How can you judge the effectiveness of a file erasing tool when the file recovery tool you're using to asses it may be unreliable?
    Two people have now given "Eraser" a recommendation - I'd say check that out. I'm gonna take a look out of curiousity...
    Carpe diem.
  29. Member
    Sep 2006
    Originally Posted by VegasBud
    fLYtRap,
    I found it:
    Eraser
    Eraser is a secure data removal tool, which allows you to remove sensitive data from your hard drive by overwriting it with carefully selected patterns.
    The program is free software, which means that everyone has access to the source code, the freedom to study it, make modifications, and even distribute modified versions of their own. This freedom has made Eraser one of the most trustworthy and popular security tools for Windows.
    As I said in my announcement in November, I have moved on to other projects and version 5.3 is the last release of the program I will make. Thanks to the GNU General Public License, other developers will be able to continue the work without me.
    New maintainer
    Garrett Trant has taken over the main branch, and will continue maintaining the program. You can find more information from his web site.
    Documentation and support
    I no longer provide technical support for Eraser. If you have a question not answered in the help file or the Frequently Asked Questions, please post a message on the support forum.
    http://prdownloads.sourceforge.net/eraser/eraser53.zip?download
  30. Member
    Sep 2006
    Well, using PC Inspector I have recover 20GB of data when my computer crashed, so its not that bad.
