Hi, I've always made vcd's using TmpgEnc to turn my avis to mpegs 1, when I burned them in NERO 5 (make VCD) it would see that the files were already decoded to mpeg and would only take five minutes to crete vcd. Now that I upgrated to NERO 6, it doesn't seem to care that the file is already in mpeg format and starts decoding it again, resulting in a 20 min delay (per file) to creat the vcd.
Is there a way to avoid this problem?
<---- Tools > Authoring > SVCD/VCD. Try any of the freeware stuff to start, if nothing it acceptable to you, try one of the commercial/shareware packages available.
With that said, have you tried turning off VCD compliancy (something to that effect)? It's been so long that I used Nero, let alone to let it compile a VCD, that I can't really recall where the tickbox is. -
Best VCD authoring app is VCDEasy (last free version will do nicely, if you don't feel like paying for later commercial versions).
/Mats
How to delete a menu & create/insert a new one with Nero Vision Xtra?
By snowseals in forum Authoring (DVD)Replies: 22Last Post: 27th Aug 2011, 00:03 -
problems burning with nero and imgburn-pixlation and long burn
By pokitisme in forum Software PlayingReplies: 5Last Post: 2nd Sep 2009, 03:12 -
how long
By Tobias0815 in forum FeedbackReplies: 3Last Post: 1st Jul 2008, 20:08 -
Final Cut Express 4 can I create chapters for a DVD I create
By Jabroni4872 in forum MacReplies: 1Last Post: 18th May 2008, 12:36 -
how to create folders in nero burning rom or express?
By jyeh74 in forum Newbie / General discussionsReplies: 3Last Post: 23rd Dec 2007, 00:54
