i bought a box of sony dvd+r and having problems copying items on them. i get a message: 'the disc in the drive is not a writable cd or it is full'. it is a new box and i can not return it. i tried to format the disc but it will not let me.
any suggestions?
much appreciated
First, I wouldn't use the built-in CD writing capabilities of windows. opt for a third party player. For data CD/DVD and audio CD writing you could look at CDBurnerXP Pro. It's free and works well. For DVD video you should use imgburn 2.
If you still encounter problems there is a good chance the culprit is the age of your burner. It may simply not recognise correctly newer discs. This can often the solved but updating the firmware in your burner. Check the burner manufacturer's site for firmware updates.Read my blog here.
The new Sony disks are version 2.0 I believe. Check the cake box. Funny though, an old HP 8x burner reads em fine, but a new HP dvd burner my bud has doesn't. I have 2 Maxell burners, same model made 6 months apart, and each one has a different minimum speed I can write to on those 2.0 disks.
Firmware is the only answer, but contact the company and make sure the update will definately allow you to burn to those Sony's, because flashing is NOT guaranteed, it may not take and your drive is ruined. If it works fine except for 1 brand, personally, I wouldn't flash for that.
For me Nero burns great with any media I have used, be it dvd or cdr
Copying DVD movies with a Sony VRD-MC6 Multi-Function DVD Recorder.. help?
By madeyeX in forum DVD RippingReplies: 14Last Post: 17th Dec 2014, 21:36 -
Problems copying VOB files from DVD to PC
By jaekim86 in forum Newbie / General discussionsReplies: 8Last Post: 19th May 2009, 03:09 -
Sony written DVD not copying on PC
By Sainkho in forum DVD RippingReplies: 4Last Post: 12th Apr 2008, 23:21 -
Problems Copying 2 Movies on 1 DVD with a menu!
By UmmAddan in forum Newbie / General discussionsReplies: 2Last Post: 9th Jun 2007, 12:42 -
Anyone had problems copying Dvd's with HP drives?
By Blumphf in forum DVD & Blu-ray WritersReplies: 53Last Post: 31st May 2007, 21:40
