this happens quite often to me, i will download a video and it will not open in any media player and has no information summary with encoding specs. however, the videos often play on a divx supported dvd player when burned onto a data disc, and some do not. for those that do not, does anybody have any suggestions to make these videos function.
also, they are of full size (ie. a television series with all videos of relative equal size 350mb), so i doubt they are a lost cause.
You could start by using g-spot or avicodec to tell you what type of video they actually are. From there you can download and install the correct codec for playback.
Alternatively, use VLC for playback, as it uses it's own codecs and doesn't require that you have them installed in most cases.
Finally, FFDShow will allow you to play back most formats through most players.
As for playback in a standalone player - each player has it's own restrictions on what is acceptable. You need to understand what restrictiosn apply to your player.
Mpeg4modifier can alter certain aspects of a video without re-encoding. In other cases you have to completely re-encode, otherwise avirecomp can be used to re-encode to suit most players.Read my blog here.
Can't play downloaded AVC/H.264 videos
By gumbygum in forum Software PlayingReplies: 14Last Post: 12th May 2011, 10:59 -
Issues converting downloaded videos
By iviet in forum Video ConversionReplies: 10Last Post: 29th May 2010, 16:29 -
Restored videos dont work!
By BVG in forum Video Streaming DownloadingReplies: 5Last Post: 7th Jan 2009, 20:50 -
How to unblock videos downloaded from limewire
By wandj in forum Video ConversionReplies: 9Last Post: 16th Oct 2008, 05:32 -
Stuttering Downloaded Videos
By RonLuxton in forum Software PlayingReplies: 4Last Post: 4th Oct 2008, 15:36
