Alright so i had an Mkv with aac audioand XviD video. The mkv was vfr so i had to do that timecode thing to convert it to cfr to get it into an avi with the audio in sync. The audio i left as wav(thinking about turning that into mp3 due to file size). Now when i try to burn it, and only when i try to burn it for some reason the video moves at an amazingly fast pace while the audio stays as it should(i use Nero). By the time the Opening song is done at normal speed the video is at the ending song.....thats how bad it is XD. Is there anyway to fix this problem or maybe i did something wrong while converting? Its weird though it has no problems while playing in VLC player though it Crashes in windows media player at random moments. Ihave no idea whats going on D:
Closed Thread
one similiar topic is enough.
https://forum.videohelp.com/viewtopic.php?t=311415&highlight=
reply to add new information.
Audio track speeds up going from AVI to DVD
By jenna1 in forum ffmpegX general discussionReplies: 2Last Post: 19th Oct 2011, 16:22 -
Burning speeds
By Rogert in forum Newbie / General discussionsReplies: 2Last Post: 1st Sep 2008, 08:28 -
DVD burner read/write speeds
By ecc in forum Authoring (DVD)Replies: 9Last Post: 13th Apr 2008, 06:49 -
Burning at lower speeds lengthens the life or your burner?
By LittleQueenie in forum MediaReplies: 10Last Post: 25th Jun 2007, 19:40 -
Burning speeds and DVD Decrypter...
By Nilfennasion in forum Newbie / General discussionsReplies: 6Last Post: 20th May 2007, 05:32
