Hello,
My question to you all is can I create a menu that has interactive images (like on actual dvds), and not simple Number selection (like in most menu tutorials for CD Creator)? I have Adobe Premiere,Photoshop, After Effects, as well as CD Creator. If it were computer programming, it'd be a bit more simple...I could just have animated Gifs w/ transparent backgrounds, although I know this won't work since I'm dealing with movie files, such as .avi, and .mpeg. Any help would be much appreciated..
THank you
Firstly, read "What Is VCD" on the top left hand corner.
VCDs don't support GIFs or JPEGs or BMP or any other type of format. They ONLY support MPEG -- either, a video sequence or a still (or audio only).
Secondly, the interactivity available to a VCD is a lot more limited compared to that on a DVD. Although you can have "selection areas" defined, these really only work on CD-i players and some software players.
The buttons that can be referenced in a VCD are: NEXT, PREV, DEAFAULT, RETURN and the numerical key presses only.
However, you can have an animated background for a menu (i.e., a video clip) and if you are clever with authoring, you can translate most of the interactivity on a DVD to a VCD with good effects.
Regards.
Michael Tam
w: Morsels of Evidence -
obviously.... i said all that crap u told me about gifs and jpegs already...i said IT WONT WORK. I also mentioned I would be doing an animated video in the background anyway...your reply was no help to my post whatsoever, sorry.
If you already knew the answer is obviously "NO" then why ask in the first place?
Regards.
Michael Tam
interactive dvd disc pin number
By dany_boy in forum DVD & Blu-ray PlayersReplies: 56Last Post: 9th Jun 2011, 20:23 -
USB Media Player with direct selection of file (picture) by number
By Safer63 in forum Media Center PC / MediaCentersReplies: 0Last Post: 11th May 2011, 18:45 -
Interactive DVD menu
By aloram in forum Newbie / General discussionsReplies: 5Last Post: 16th Jan 2010, 01:10 -
Adding extra material to the end of a simple 1 movie dvd (with simple menu)
By ColinKe in forum Authoring (DVD)Replies: 4Last Post: 24th Jul 2009, 22:38 -
Creating a DVD with Interactive Menu
By magus2008 in forum Authoring (DVD)Replies: 11Last Post: 20th Nov 2008, 06:33
