I have a bunch of video files but the audio volume on them are really low, you have to jack up just about every volume setting on the computer to get it to play normally. Is there a program or something that can just take a wmv file, increase its volume, and then make it a new file? Thanks!
-Dave
Thank you. I'm looking into this right now. Now only to figure out how to use the app...
ok, i see what i have to do to get the file reencoded with higher audio volume, but I think there's something wrong with my application or computer: There's supposed to be 4 or 5 controls in the "audio panel" in Windows Media Encoder, but instead the audio panel loads no controls and all grayed out or only has a volume display. How might i fix this?
OK, worked out the audio panel issue, though I just did some test recordings, and apparently i set the video source as an wmv file, and the audio from system mixer. But the new encoded file doesn' thave sound. Most likely because WME9 is taking video fine, but the audio is not played and so not encoded during encoding. Does anyone know of a way to jack up the volume of a wmv file, not necessarily using Windows Media Encoder?? Thanks in advance!
Increasing Audio volume on AVI/DivX/Xvid with AC3 Audio
By Spacedementia87 in forum User guidesReplies: 21Last Post: 24th Dec 2021, 08:21 -
Time Lapse Video from existing WMV file
By willboss in forum Newbie / General discussionsReplies: 5Last Post: 17th Sep 2013, 03:35 -
Increasing Video Volume
By edlimym in forum Newbie / General discussionsReplies: 2Last Post: 24th May 2010, 07:41 -
Increasing volume in GKnot
By Fire Foxer in forum EditingReplies: 6Last Post: 7th Aug 2009, 09:08 -
[SOLVED] WMV to MPEG4/AVI/anything else has increasing audio desynch.
By Eilonwy05 in forum Video ConversionReplies: 13Last Post: 15th Jun 2008, 15:01
