can someone please help.. i have svcd's extension *.m2v is playing upside down. does anyone have a fix for this?
Results 1 to 11 of 11
i just downloaded the video. I used windows media player on xp to play. it plays upside down. but if i use powerdvd it plays correctly. its just i would rather use windows media player to play all my videos
It seem to be a kind of codec or DirectX problem, not sure about that. Since PowerDVD play it properly, it is encoded in the right way. If you can not find a solution, but want to play it with windows media player by all means, you could reencode the file using a flip-vertical filter.
thanks,
where would i get flip vertical filter and what encoding software should i use? -
VirtualDub as well as Avisynth come with flip-vertical filters.
VirtualDub:
Open the MPEG-2 file in DVD2AVI and create a project.
Convert the project with VFAPIconv to a fake avi.
Open that in VirtualDub, add the flip-vertical filter and start the frameserver.
Load the *.vdr into your favorite MPEG encoder (for example TMPG)
Avisynth with mpeg2dec plugin:
Write a sript with notpad as follows
LoadPlugin("c:\..path..\MPEG2DEC.DLL")
mpeg2source("d:\..path..\filename.d2v")
FlipVertical
Save it as filename.avs and load it into your favorite MPEG encoder.
http://www.vcdhelp.com/DVDConversionGuide/index.php?id=dvdtovcd2c.html#DVD2AVI
http://www.vcdhelp.com/DVDConversionGuide/index.php?id=dvdtovcd2a.html#VFAPI
http://www.vcdhelp.com/faq.htm#frameserver
http://www.doom9.org/mpg/tmpg-main.htm
http://www.horizon.nl/~michel/uk/default.htm
http://www.vcdhelp.com/vcdtools.htm
http://www.doom9.org/mpg/d2a-mpeg2dec.htm
<font size=-1>[ This Message was edited by: Truman on 2002-01-12 20:04:26 ]</font> -
Why don't you just turn the monitor/television upside down?
<font size=-1>[ This Message was edited by: JStyle on 2002-01-12 22:26:44 ]</font> -
Upside down video in WMP8 using Xp is a known problem to solve it try
WM8/ Tools/ Options/Performance/Advanced/Uncheck "Use Video Mixing Renderer
I think this works -
Thanks, CHyRO, I had the same prob and your fix worked great. Now if I could only get the audio synced in WMP8....
thanks and this solved the problem with mediaplayer but powerDVD is still inverted. it was not so before i loaded the codecs after reloading xp. so there must be a global solution that fixes the problem instead of fixing it by defeating features in each program.
realized that the problem is that avi are inverted in all players, mpg play just fine.
running xp
thanks
Thumbnails (FRAPS) upside down
By terrypin in forum Newbie / General discussionsReplies: 0Last Post: 24th May 2011, 02:31 -
Vegas 8.0 - ITS UPSIDE DOWN!
By 1320Video in forum EditingReplies: 7Last Post: 17th May 2008, 12:35 -
upside down play back
By suomiaussie in forum Software PlayingReplies: 2Last Post: 14th May 2008, 13:22 -
avi files upside down
By nocash in forum Newbie / General discussionsReplies: 1Last Post: 26th Mar 2008, 07:13 -
My video is upside down
By Baldrick in forum Newbie / General discussionsReplies: 42Last Post: 7th Oct 2007, 10:02
