I have a 8MB ADSL connection but how do I find out what I really have? When I connect up it always shows 2.2 Mbps in the bottom corner and when I download things the speed varies from 50kbps to 140kbps.
thanks
http://www.bandwidthplace.com/speedtest/
http://www.pcpitstop.com/internet/default.asp
http://www.dslreports.com/stest
http://testmy.net/
http://speedtest.clover.net/
Also read...
https://forum.videohelp.com/viewtopic.php?t=306661&highlight=speed+test
https://forum.videohelp.com/viewtopic.php?t=303463&highlight=speed+test
https://forum.videohelp.com/viewtopic.php?t=296038&highlight=speed+test -
Huh? I've got a 448Kbps connection here and I get downloads around 44K.
Sounds like yours is way underspeed or you are on websites that throttle speeds.
At home I have 3Mb DSL and I see throughputs that match that speed. My brother who I kindly connected to it via the built in router and a long ethernet cable going two floors up gets good speeds downloading videos from the aviation websites he visits. While I was talking to him the other day he wanted some spyware checker to run. It downloade and updated in nothing flat unlike here at work. We are well past the distance limit So I suppose I should be glad I is reliable.
Install this free 10 day trial, set it up to work with newsgroups, select some binary NGs and let er rip, it will report speed somewhere in the lower left as I remember it.
http://www.newsbin.com/index.php?mode=files&task=viewfile&file=13&tab=rl
I suggested this application as it will show realworld throughput
Or call your provider and have them check the connection. They should be able to view the modem and check it out that way. -
Switch to Cable or DSL. I got constant speed of 100.0Mpbs
moved to another forum, nobody likes me here... -
ADSL is DSL, it pretty much meanshis/her download speed does not equal his upload speed. ANd the 100Mbps you get is probably between the router/modem and your NIC, not you downstream speed.
Vijaygunners, in addition to 3Simon's links, have you set port forwarding up? You're not saying if you're downloading from a website, or (legit) P2P, etc. My download speeds are about 300K from websites and ftp on a 3Mb line. If you go to http://www.portforward.com you should be able to find instructions for your router.
Internet speed its different everytime, check this out I just did 3 test 1by1:
1- 3.3 megabits per second
Communications 3.3 megabits per second
Storage 399.4 kilobytes per second
1MB file download 2.6 seconds
Subjective rating Awesome
2- 4.1 megabits per second
Communications 4.1 megabits per second
Storage 498.8 kilobytes per second
1MB file download 2.1 seconds
3- 4 megabits per second
Communications 4 megabits per second
Storage 489.2 kilobytes per second
Subjective rating Awesomemoved to another forum, nobody likes me here... -
It depends what you're downloading. 2.2Mb/s will max-out at around 235KB/S. You'll be lucky to get half that with BitTorrent which is about what you're getting now.Originally Posted by vijaygunners
Security risks for wireless broadband?
By yogart in forum ComputerReplies: 10Last Post: 16th Feb 2010, 13:49 -
IPS Wireless Broadband security
By yogart in forum ComputerReplies: 0Last Post: 8th Feb 2010, 12:45 -
Changing Broadband From AOL To Sky Help
By Nitro89 in forum Off topicReplies: 0Last Post: 12th Dec 2008, 15:36 -
Mobile broadband USA
By rhegedus in forum ComputerReplies: 14Last Post: 1st Nov 2008, 12:26 -
Comcast to cap monthly consumer broadband starting Oct. 1
By stiltman in forum ComputerReplies: 38Last Post: 31st Aug 2008, 11:07
