    Oct 2006
    Hi i would like to make a comilation dvd from clips of other dvds. So far i have been able to rip just the clips i wanted and save them in an ISO format using dvd shrink. However i have no idea where to go from here. I am looking for a program that will finish what i started or if i need another program that will do it all in one. Is there a freeware way or is there a program that one can buy that would do it all. Please i could use some help in this matter. The other thing is that i would like to keep the quality at least close to the original.
  2. Rip the VOB's with the video you want using DVDDecrypter and if you need to join any use VOB2MPG.You could also rip VOB's with DVDDecrypter in IFO mode and set file splitting to "None" leaving 1 VOB that can be saved to MPG with VideoReDo.
    Edit the MPG's with software like VideoReDo (Trialware!) and save.
    You can then use TMPGEnc DVD Author to import the MPEG files and author to DVD Video Files and if the contents are too large to fit onto your blank DVD media then transcode with DVDShrink to ISO and burn with IMGBurn.
    TMPGEnc DVD Author can also import parts of DVD's.You can select the title,audio format ect...
    ~Luke~
