I recorded some footage while the clock in the cam was wrong, exact one year off.
Is there a tool to adjust the Datacode in the DV AVI file with an offset, just as there are tools to adjust the Exif datetime in .JPG files?
I do not want to 'burn' the date in the frames but only want to update the datecode itself, without modifying the recording.
Results 1 to 17 of 17
strip out the date first
add new date"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
or live with it
ok - maybe not .. i thought it did ......
you strip out date code anyway by restreaming it in vdub ....
you could do it with two cameras though -- just change the date on the recording one ....."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
This probably won't work - see https://forum.videohelp.com/viewtopic.php?p=1592023#1592023 - unless the recording device can be configured to write new date/time.Originally Posted by BJ_MJohn Miller
How urgent is your need?Originally Posted by jaapg
If you have Windows XP and an SSE2-capable processor - and you can wait a week or two - we will be adding this function to our Enosoft DV Processor (it's been on the to-do list for a l-o-n-g time).
John.John Miller -
It is not urgent, just personal recordings form earlier this year, I do have a capable computer. I will wait with patience for the development of the Enosoft DV Processor!Originally Posted by JohnnyMalaria
Actually DVdate can modify the datecode inside a DV file, but only by adding or substracting an integer number of hours. It's called "Fix a time difference" in the menu "Convert". This feature is useful if you travel abroad and forget to modify the time of your camcorder, or if there is a change in summer/winter time and you omit to change it in your camcorder.
In the next version of DVdate (to be published before end of october) the integer hour limitation will be removed, and you may correct a datecode by any time difference (even years, seconds etc...)Paul Glagla
http://paul.glagla.free.fr/index_en.htm -
I did look at the "Convert->Fix a time difference" option but it is not selectable (grey), I looked at the help on http://paul.glagla.free.fr/dvdate_7_en.htm, but this is for version 5 an this option did not exist then.Originally Posted by Paul Glagla
Option "Inlay" is selectable though and works as expected.
Great! The more choice, the better.Originally Posted by Paul Glagla -
That is a very usefull feature - I did exactly that (record in US something with Romanian timestamp).Originally Posted by Paul Glagla
Thank you for your free software! -
I had a similar issue: I wanted to process DV files (DESHAKE) without changing the date/times. I found that I could save the timestamp info with AVCutty, then, after I processed the DV, I could restore the date/time info, then save all the scenes in the DV.
However:
AVCutty is a little buggy - The latest version (2.4d) sometimes seems to stop saving the video before it's done. The previous version (2.4c) sometimes gives me a weird error message and refuses to save anything.
(Now I use VDub to split up DV, I really don't trust AVC very much anymore)
Anyway it does restore the date/times, and since it's from an ASCII file, you can modify the date/time for each scene. Make sure when you save the timestamp info, that it's a format that it can import. -
OOPS!
I screwed up! I thought I had put dates on the file that went through the processing, but the filename in the scene list caused the original file to get rendered wilth AVCutty.
So basically we're all back where we started. Is there anyway to get dates/times back into DV files?
It seems like a simple thing to do. Read some form of scenes list, go to the indexed frame in the DV file, and start incrementing the date/time until the frame that the next scene starts on.
I'm a little confused why the Datecode comes up "N/A" and Timecode stays "00.00.00.00" throughout the file. (Panasonic codec). I would have expected the file to have the date and time it was produced by the codec.
I hope this thread still has some life in it.
Sorry for the initial confusion
Glenn Foulke
mts file datecode
By mpegjohn in forum ProgrammingReplies: 3Last Post: 7th Jan 2012, 10:48 -
How to stamp DateCode on DV files...
By FatBoy123 in forum Newbie / General discussionsReplies: 4Last Post: 24th Jun 2011, 09:06 -
inlay datecode on AVCHD
By jjblackisback in forum Video ConversionReplies: 10Last Post: 4th Apr 2011, 15:44 -
How to import dv to Mac and keep datecode information?
By dmelgar in forum MacReplies: 1Last Post: 13th Jul 2010, 16:12 -
Dubbing DV-DateCode to DVD
By cissywik in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 9th Jun 2009, 04:45
