Has the option to just create an ISO and no burn been removed from the latest version or have i gone blind?
It has gone for the moment. Is there a big need to bring it back?
I used it for all my all my projects as i normally use it remotely from work so it is ready for when i get in.
If it doesn't come back i will just have to run it though dvd shrink to get my iso. -
No need i will add it in the next release.
Alternatively you could use the ImgBurn Shell Ext to create an ISO from the VIDEO_TS folder and burn it on the fly...SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Howto create an ISO file
By marlo in forum MacReplies: 2Last Post: 4th Jan 2012, 13:56 -
How to create an ISO image file from a disc under UNIX.
By valeyard1492 in forum LinuxReplies: 11Last Post: 11th Sep 2009, 20:11 -
how do i get dvdshrink to create an iso file
By rmb3 in forum DVD RippingReplies: 8Last Post: 29th Sep 2008, 14:34 -
create a dvd menu from iso image
By DSLGuy in forum Authoring (DVD)Replies: 3Last Post: 19th May 2008, 10:30 -
Cannot create ISO file with this type VIDEO_TS menu, Why ?
By RWANDREWS in forum Authoring (DVD)Replies: 2Last Post: 30th Apr 2008, 13:44
