Is there anything I can do to enhance the sound of a Solo guitar performance in Vegas 6? It already has a litle reverb and chorus on it, but I remembe one time someone took an audio clip I posted and did something with what he said was the compressor and it sounded really good... anyone know what that is?
Results 1 to 21 of 21
http://www.pacificsoundcraft.com/software.shtml
Free DirectX audio effects. The compressor and limiter are pretty good, especially for free. -
thanks,,, what exactly does a compressor do though? I recorded very clean audio through an audio rack (alesis mixer and presonus bluetube)
thanks for the link, I read: "Guitar sounds are often compressed in order to obtain a fuller, more sustained sound."
That's what I'm looking for but I don't know how to use the tool to accomplish that... Do you know of any sites that tell you how to actually use it? I messed around with it but all I got was a bunch of clipping ... -
ha! Vegas is expensive enough
I'm messing with the compressor, read the help file on it in Vegas but I still exactly know what I'm doing. just playing with the slider bars and getting either a lot of distortion or it goes very quiet so I'm not getting the hang of how to use it =( -
you will not get much improvement using only the vegas compressor .. in what you are trying to do ....
post a sample or send me a sample and ill fix it..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
OK, here's the file:
http://www.filelodge.com/files/room22/568910/audio.wav
You're like the "easy" button on that staples commercial, just press it and you fix everything.
But can you explain, for my own good so I don't have to ask for help about this again - how you arrive at the settings you did when you fix it? -
not a complete file - it is a broken wav file you posted (6kb)
try again?
Man, filelodge is slooow, know of a better site? -
BJ_M: Sorry for usurping you, just read through the thread again.
Tough one. You're clipping a bit from 8 sec to 11 and from 21sec to 27 sec. The bass notes get kinda boomy, although that's jazz guitar for you. Sounds like a hollowbody through a 12-15" speaker?
Here it is with light compression - enough to hear it but not enough to sound like FM radio.
http://www.megaupload.com/?d=TA4YX24D
(Warning - you might get a popup for 'women seeking men' during the download - tame)
BTW - The "better" free audio effects utilities exist in the VST world, which Vegas doesn't directly support. However, you can download this DirectX2VST wrapper.
http://www.spinaudio.com/downloads.php?download_type=3&download_id=33
These VST effects are free and pretty sweet (there are tons of them out there)
http://digitalfishphones.com/binaries/dominion_v1.2_PC.zip - Several Presets included
http://www.smartelectronix.com/refer.php?url=~bram/files/H2O_v1.0_Win.zip - Basic Compressor -
Soopafresh,
Regarding the clipping, I don't see that at all in the time frames you mentioned or anywhere else in the file? I'm looking at it on the timeline in Vegas. (Between 8-11 seconds, the highest output level is -3.5) and the highest level in the whole song is at 56 seconds at -0.9dB...It is a hollowbody guitar, but no speakers, going through a small audio rack direct into the camera.
That audio file you uploaded sounds really great! You didn't do that with Vegas did you? I kind of understand from reading, what compression is but I still can't figure out how to work it. Is there a website, or tutorial somewhere that explains how to actually set the parameters? -
You're probably right about the clipping bit - My machine is long overdue for a reinstall. It was this that I saw:
I didn't use vegas for the compression, although it is absolutely up to the task. Actually, Winamp with the VST plugin adapter would work equally well for this particular task. It's just a matter of finding the sweet spot that doesn't sound artificial and doesn't send everything into the red. Before I throw any "sauce" on top of the original audio, I'll usually normalize it to -2db to avoid overloading the signal.
Here's an introductory guide. Google "Audio Mastering +Limiter +VST settings" for more.
http://www.remix64.com/faq_tut_digital_mastering.html
And here's the BEST free limiter out there for VST.
http://www.betabugsaudio.com/plugs.php (download the W1 Limiter). A limiter is basically a compressor on steroids. That one is an exact replica of the Waves L1 Limiter - a plugin that costs several hundred dollars.
=Some Settings to dial in with the W1=
Name...................................Thresh..... ...Ceiling........Release
High Res CD Master ..............5.0..............0.2.............1.0 (a favorite)
Track Slammer......................18.0............9.0.. ...........1.0
Hard Limiting.........................10.0............2 .0.............1.0
FM Radio...............................5.0........... ...5.0.............1.0
Baseball Game.......................23.0............21.0... ........2.0
Originally Posted by BJ_M -
no - ver 6 also supported completely VST plug ins
Oh, then in that case sdsumike619, just download the W1 Limiter and enjoy
Thanks for that info, BJ_M
wow I don't know how I missed all those replies, I'll check into those VST deals now..
I like this W1 thing, 3 knobs! Now we're talking! Thanks for the settings suggestions too, now I'm stylin =)
Video Enhancement
By rckowal in forum RestorationReplies: 20Last Post: 13th Dec 2011, 13:54 -
Audio of video enhancement
By ginny02 in forum AudioReplies: 16Last Post: 19th Jun 2010, 14:56 -
Vegas 4 vs Vegas 8pro audio levels
By schematic2 in forum EditingReplies: 2Last Post: 19th Feb 2009, 20:57 -
Video enhancement software
By terryxpress in forum MacReplies: 4Last Post: 30th Aug 2007, 11:37
