Dear Friends,
Is there a way to convert/adjust a commercial DVD (Sand Pebbles) from wide-screen to full-screen? The wide-screen seems to cut off too much of the top and/or bottom of the picture for my taste but I don't know whether there *is* anything more at the top or bottom. Is there?
Regards,
Jack Owens
No, what you see is what is there unless VistaVision and you have access to the original prints.
https://forum.videohelp.com/viewtopic.php?t=311107&highlight=cinemascope
http://www.widescreenmuseum.com/widescreen/lbx.htm
http://www.widescreenmuseum.com/widescreen/lbx3.htm
PS: Looks like "Sand Pebbles" was only released as 2:35 to 1 on DVD. Original film was shot as Panavision. -
only option since they never released a full screen version is live with the letterboxing which is what I would do.
Or if you player has a zoom buttton use that keeping in mind that you will lose action on both sides of the screen or if your TV has a zoom/fill button. I have a zoom function on a DVD player and my TV. The only time I zoom something is if it is a SD letterboxed video and is not filling the screen side to side. Then I zoom until it fills the screen side to side. The black bars above and below do not bother me. I'd rather see the whole thing rather than cutting off the sides. -
The Sand Pebbles was shot in Panavision anamorphic with 70 mm prints in 2.20:1 and 2.35:1. It is the 2.35:1 print that is used for DVD transfer for this particular film. There is nothing top and bottom that you are missing. Converting this to full screen would in fact throw away nearly half the image.
Read my blog here.
Change DVD aspect ratio
By drgt in forum Newbie / General discussionsReplies: 11Last Post: 4th Oct 2010, 22:45 -
Aspect ratio changer for DVD?
By vato76 in forum Authoring (DVD)Replies: 3Last Post: 23rd Jun 2010, 02:29 -
Changing a DVD's Aspect Ratio
By soneman in forum Authoring (DVD)Replies: 11Last Post: 8th Sep 2009, 19:18 -
AVI to DVD with different aspect ratio
By germ in forum ffmpegX general discussionReplies: 16Last Post: 7th Apr 2008, 23:50 -
DVD aspect ratio
By SWBisbee in forum Newbie / General discussionsReplies: 5Last Post: 18th Oct 2007, 00:52
![Computer details: Windows XP Home
Intel Pentium M 1.60GHz
40 GB
512 MB
Mobile Intel(R) 915GM/GMS,910GML Express Chipset F
HL-DT-ST RW/DVD GCC-4244N [CD-ROM drive]
Hewlett-Packard 09BC 35.30
Comp](/images/buttons/computer.gif)
